The BBQ and Smoking Thread - Page 73 - Beyond.ca - Car Forums
Page 73 of 144 FirstFirst ... 63 72 73 74 83 ... LastLast
Results 1,441 to 1,460 of 2870
Thread: The BBQ and Smoking Thread
  1. #1441
    Hybrid
    Anyone have any tips on getting those add on smoker boxes to work with their propane grill? Seems like I can never get the right balance, the woodchips either turn into a raging inferno or don't even smoke at all.
    I've read good things about the A-maze-n version of a smoker box if you're determined to try and smoke on a gas grill.
  2. #1442
    Anyone have any tips on getting those add on smoker boxes to work with their propane grill? Seems like I can never get the right balance, the woodchips either turn into a raging inferno or don't even smoke at all. Attachment 94688
    Soak wood for 24 hr beforehand.
    They work, but require much more hands on to keep them smoking properly.
  3. #1443
    Quote Originally Posted by ercchry View Post
    More like a wolf toaster... just no red knobs
    You clearly know nothing about wolf toasters.
  4. #1444
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    You’re probably right... I guess a toaster is a closer sibling to an electric smoker
  5. #1445
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    I just noticed that a Wolf toaster costs more than a Weber Kettle.
  6. #1446
    May 2008
    Wildflower Ranch
    I make better fried rice than bbq. This came out of an Instant Pot before finishing in a Toaster.
  7. #1447
    Mar 2006
    Picked up a 4.5lbs pork shoulder this week. Gonna try it out this weekend. Any one have some tips or solid recipes? It will be my first time doing a shoulder.
  8. #1448
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by Ca_Silvia13 View Post
    Sounds like boneless picnic?
    Rub: brown sugar and paprika is a must. Play with flavours from there
    Coat in margarine, beef fat, or mustard so the rub sticks to it well, only add smoke for the first couple hours
    Wrap at the stall, pull it at 203F... keep juice from the wrap, mix with bbq sauce and add back in after you pull the meat for extra juiciness
  9. #1449
    Mar 2006
    Pull at 203*F? Not 165*F?
  10. #1450
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    You want pulled pork, right? 203F... wrap it at 160-165F
  11. #1451
    Oct 2003
    ute
    def not 165
  12. #1452
    Mar 2009
    Silverado
    Going for my first brisket tomorrow on my kettle. Tips?
    Simple rub. fat cap side down.
    15 pounds. Planning on getting it on about 6 am. Going to do the snake method. 2x2 with an extra on top. Wrap at 150-160..
    Hopefully an hour or two in the cooler.
  13. #1453
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by dirtsniffer View Post
    Just keep an eye on the charcoal, you’ll get an idea of how often you will have to turn the grill to keep the fire indirect. Make sure to push all the ash/burning charcoal back into a tight pile too so when you do turn you’re not over top of that as well (gives off a fair amount of direct heat even if the ash looks done)
    Also don’t forget a tin/baking pan/whatever full of water to keep temp fluctuations down
  14. #1454
    That sounds like too much charcoal. Define what you mean by the charcoal thing you said, please.
    Like what's his name mentioned, if at any time, any portion of the meat is overtop of lit coals, it's going to incinerate it. Be weary of that because that's a big chunk of meat for what could be a small Weber.
  15. #1455
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Royal oak (briquettes) yes, kingsford, no... depending on ambient temp. Tomorrow looks nice, I’d personally do one on top every other row... after the wood chunks are done, those give off enough heat that 2x2 is fine. Vent at full open and this should maintain a solid 225F-250F at the grill (250F in the lid). Of course assuming you get a good lit 9-11 briquettes to start it off.
    Full packer fits a full sized kettle just fine. Also it IS a big piece of meat, little fire. If you are a touch late to turning it it’s really not the end of the world. Just keep the point side closer to the fire and the flat furthest away and it’s easy.
  16. #1456
    Mar 2009
    Silverado
    22" kettle. Kingsford briquettes. Looking forward to it.
    Edit. Started a little late. On the kettle at 7.
  17. #1457
    Aug 2004
    I have a Beef Loin Roast with a heavy fat back that I want to put into my Electric smoker tomorrow.
    Way different than a brisket...
    Suggestion on cooking times ? Or just do the same...
    Standard rub
    Set smoker at 225
    Wrap at 165-170 and finish
    Thoughts ?
    Thanks.
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
  18. #1458
    I don't know much, but for a roast aren't you aiming for a MUCH lower internal temp than a brisket?
  19. #1459
    Mar 2006
    Standard rub
    Set smoker at 225
    Thoughts ?
    Thanks.
    You could brine in beef stock overnight otherwise 225 for 4-5 hours should be good. Assuming it's around a 5lbs roast. Internal thermometer is your friend.
    I do not wrap my beef roasts in the smoker and they still come out deadly. Aim for 130-135 internal depending on how you like it done. Make sure to let it rest at least 20 mins (longer is even better)
  20. #1460
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    What type of loin? Strip? Rump? Sirloin?
    Steaks if it’s a nice cut, if not then yeah, same idea in prep and indirect heat and temp.. but bring up to ~125F internal then hit with some direct heat to finish. Not enough connecting tissues and fat to bring it up to a high internal like brisket. I’d probably cut the excess fat off of leaving it as a roast so you get better adhesion from the rub
  1. Replies: 52
    Latest Threads: 05-07-2014, 03:48 PM
  2. Who's into BBQ? Proper BBQ - Smokey, low & slow
    By r3ccOs in forum Food and Dining
    Latest Threads: 03-01-2010, 11:30 PM
  3. FS - 1 Propane BBQ & 1 NG BBQ
    By sluggish in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-04-2008, 09:22 AM
  4. *The Unofficial Beyond BBQ Thread*
    By BerserkerCatSplat in forum Food and Dining
    Latest Threads: 05-24-2005, 09:53 AM
  5. Official Beyond Cruise to the Mountains + BBQ Thread!
    By Team_Mclaren in forum Events and Meets
    Latest Threads: 05-07-2005, 11:24 PM
