Here is what I am looking for, I will add and subtract as necessary.
b-series obd1 dizzy
**If anyone happens to see a Del Sol when out at the junkyards, can you let me know what yard has one?? I am looking for some misc pieces.
Updated
b-series obd1 dizzy
Updated
Signature..... I ate it!!
Just a heads up if you don't know already, but the b series mounts for a del sol are the same mounts as the stock d series.
Axles should be any 94+ integra or 99-00 Civic Sir, or any del sol dohc
Honda/Acura guy
Pm'd Lenny
Deetz, how sure are you??? The 93 del sol si came with a d16z6. I am almost positive I need b series mounts for a del sol/ eg. Your trader reviews indicate you know your stuff, but I don't want to get half way into putting the motor in and have to stop and scramble for mounts. Anyone else have in site into deetz statement??
Can anyone confirm if ek axles will or won't work?? I am reading mixed stuff all over the place!! The only thing I know is that I need a special del sol shift linkage....
Brad, EK Axles will work as long as the motor its from is a DOHC... so integra axles are your best bet.
Bump for Update
MOUNTS
Engine Side Mount (Timing Belt)
- use the mount from a 99-00 Civic SI (B16A2) or JDM B16 (Civic EG/EK chassis) - Honda Part # 11910-P30-000
- reuse the D16 studs
- reuse the D16 bracket
Engine Left Front Torque Mount (Air Conditioning Bracket)
- use the GSR mount
Transaxle Rear Mount (Towards the Firewall)
- use the bracket (T shape) from a 99-00 Civic SI - Honda Part # 50827-S04-N10
- reuse the D16 mount (rubber chassis isolator)
Transaxle Right Front Torque Mount (Towards the Bumper)
- use the mount from a Del Sol VTEC/99-00 Civic SI (Canadian SIR)/94-00 Integra
- use the stock D16 Civic/Del Sol stock rubber chassis isolator and studs.
Transaxle Mount (Passenger Side)
- use the stock D16
If you don't want to pay $200+ for a VTEC shift linkage, then use any B-series and have it custom welded to the right length.
PM me if you want my research. I have tons of it for a Del Sol.
Bump for ASAP update
This is from the Hasport swap guide.
94-95 B18C & 92-95 B16A (also LS-VTEC CR-VTEC)
(96 up B16A and B18C including Type R)
90-93 Integra axles, 94 up Integra axles, 94-97 Del Sol VTEC axles or 99-00 Civic Si axles.
Note: The intermediate shaft seal in the left side of the transmission is different for 90-93 Integra axles. Depending on axle transmission combo, it may have to be changed.
Kronos - Thanks for the info. I was able to pick up a set of axles that I am pretty sure will work. All I need now is the OBD1 B-Series Dizzy (2 plugs).... everything else is hopefully taken care of.
