HELP: Key stuck door Honda Civic - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: HELP: Key stuck door Honda Civic
    1.8GHZ of V-TECH
    Default HELP: Key stuck door Honda Civic
    I got a 96 hatchback civic and when i was leaving school earlier tonight i unlocked my door but the key get stuck in the door.
    Its stuck in the right (unlock position), it wont budge at all and i dont wanna force it in case the key snaps.
    This happened once before but when i put a lighter up to it, it loosened up in a matter of seconds. This time i tried a lighter and a hair dryer when i got home but still nothing.
    Anyone know anything else i can try? Maybe if i leave it overnight it will loosen up? (I put it in the garage for now)
    Aug 2008
    09 WRX
    Lube that shit up.
    WD-40
    1.8GHZ of V-TECH
    I guess i gotta go grab some tomorrow. Just a quick question about what could have caused this. I left my window open just a tiny bit (not even enough room to fit your finger in) could this have somehow caused it?
    Also my girlfriend went to my car today but couldnt lock it at first cause she didnt know she had to pull the handle then lock it, so she kept trying to force the lock switch to the lock position. She finally managed to lock it after the 3rd try, but could this have done something to the lock cylinder or anything?
    Thanks
    Jul 2008
    '16 F150 Lariat, SW20 MR2
    sounds like you have ice buildup inside the lock cylinder
    Sep 2008
    lol thought this was you
    http://answers.yahoo.com/question/in...4181022AAqNGdm
    but i also can recall SOMEONE on here saying that wd-40 inside a lock can gunk up the tumblers and such, and not to do it. I cant recall the thread, so use some caution as well OP. I would say perhaps a lock de-icer may be a better idea to try first
    Originally posted by Modelexis
    If I have questions about my phone bill, I don't post it on beyond, I call telus.
    Originally posted by D911
    worst part is definitely when the dudes smacking it with his dick like that inside out anus owes his dick some money.
    the crap you find when you dig through ask leo
    Jan 2005
    C/AB
    AP1 / CRV
    Could also be worn tumblers in the cylinder. Putting light torque on the key and giving it a wiggle up and down can sometimes do the trick to free it up if it is worn tumblers. Try lightly turning both ways and giving the key a jostle to reposition the tumblers if it in fact that. As mentioned lock de-icer would help too.
    If not might be ice, or some other form of mechanical binding with the mechanism.
    Good luck.
    Sep 2008
    ^agreed, ice is unlikely, but perhaps at least the de-icer might make for a good SAFE lubricant, try also sorta knocking the key around with perhaps a screw driver or small hammer while you turn it, perhaps itll free it up
    1.8GHZ of V-TECH
    Yeah tried playing around with it for about 15 minutes, but nothing happened at all. Ill get some de-icer tomorrow i guess and give that a go
    1.8GHZ of V-TECH
    Got the key out by keeping a lighter close to it and wiggling it around
  1. Key Stuck in Ignition
    By a social dsease in forum Mechanical
    Latest Threads: 10-21-2011, 05:18 PM
  2. how do you take a key out of a laptop key board?
    By ercchry in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-09-2010, 12:25 AM
  3. Key stuck in the ignition
    By rumeo in forum Mechanical
    Latest Threads: 12-14-2009, 12:41 PM
  4. My key gets stuck!
    By Bean in forum Mechanical
    Latest Threads: 06-12-2003, 03:09 PM
  5. key is stuck
    By redline_13000 in forum Mechanical
    Latest Threads: 04-17-2003, 02:02 AM
