Hey guys,
Hope you guys are enjoying your weekends. I see some of you guys are up in Edmonton already for the 780 UC meet.
I am beating a dead horse here but I am going to post it anyways to see what you guys think. My mechanic told me to just check the oil when the engine is cold in the future.
To be perfectly honest, it's not even something I should agonize about but I got nothing to do right now so why not eh?
So I was filling up the other day and I noticed that my oil is low. I recheck it again to make sure my reading is accurate. I don't trust this reading due to the shape of my dipstick handle, you kind of have to twist it to get it out once you have dipped it back in.
I usually see oil all over the place when I check but I do it during fillups when my engine is at normal operating temperature.
So I just simply drove it for about couple weeks and when I checked it at my mechanic's place, he told me that it was below the "ADD" mark so I added some.
I let it run for a day (Correct me if I am wrong for doing it, but I just did it so that at least the new oil would filter some of the impurities from the previous oil that had been put into the car. And the car was running low on oil) and took it to Honda for an oil change.
I tell the guys at Honda about this and they say that all VTEC motors burn oil so they told me to change it frequently.
I told them that according to Amsoil (5-20 XL Synthetic + Amsoil filter is what I use), an oil change should last anywhere between 10000-15000 MILES. It's roughly been 9000 KM since the last change.
My questions:
1. Is that true that all VTEC motors burn oil? The car does have close to 200,000 KM but the vast majority have been on the highway. I let the car warm up without idling too long (Drive away when RPM gets to around 1100 because that's when the temperature gauge starts to move up a little bit) before I drive. I do hit VTEC or redline it every once in a while to release all the carbon.
2. If the VTEC motors don't burn oil, would running the car with a low amount of oil affect compression ratio on my engine?
3. Is it bad to put oil into a car without changing the filter even when Amsoil filters are supposed to last 15000 Miles)? I didn't have a choice at the time because I was already running low on oil. Was it a right thing to do for me to just add the oil and drive it for a day hoping that the new oil will collect some of the sludge and change it again? Or should I have just kept driving and keep adding oil when it's low?
4. One of the Honda Tech told me that the oil filter was leaking oil, but said it shouldn't have leaked that much. Would this be a main reason why my oil level was low? How does that affect engine performance/maintenance other than losing oil?
5. All the oil changes were done by a Honda Tech. Do you guys think this is worth going after Honda for some sort of in-store credit? I don't have any proof that Honda didn't install the filter properly on the previous oil change...
Sorry about the long post but hope you guys understand. Any constructive criticism is welcome. We had a little bit of rain here in Edmonton but hope tomorrow is perfectly clear for a nice cruise.
