FS misc j body parts, misc turbo pieces/oil lines - Beyond.ca - Car Forums
Results 1 to 1 of 1
Thread: FS misc j body parts, misc turbo pieces/oil lines
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    Default FS misc j body parts, misc turbo pieces/oil lines
    tan cavalier headliner for a sunroof car, has everything and in good shape
    2.4 power steering pump
    2.4 head with cams and full valve train
    2.4 power steering pump pressure side hose (brand new)
    2.4 throttle body with sensors
    2.3 HO injectors
    95-99 air bags with sensors and everything to work
    2.4 block with 2 cranks
    2.4 rods/pistons and full bottom end
    2.4 intake manifolds
    idi covers
    MSD 8.5mm spark plug wires for a 2.2 or 2.4 coil swap (brand new)
    2.4 coil packs and icms
    2.4 stock springs
    autometer ultra lite narrow band a/f gauge
    trunk net
    rear fender liners like off the 03+ cavaliers (brand new)
    12" rotors for rear big brake kit, someone will have to fab something up though
    3/8 -> -6 quick connector with -6 stainless braided line and includes the fitting for the fuel rail thats threaded to the -6
    spec lightweight flywheel for a 2.4 (needs a new friction plate) $125 for the flywheel and $200 for the flywheel and i get the friction plate for you
    5x black 2.5" reinforced couplers
    1x black 4" coupler
    1x 2.5" t bolt clamp
    2x 2.75 t bolt clamp
    misc -10 aeroquip fittings
    45* part # is fcm 4024
    90* part # is fcm 4034
    60* part # is fcm 4084
    arp headstud parts for a 2.4
    have the washers/nuts and 2 of the short studs, can get the long studs no problem and ship as a full kit
    Big 5000+lbs brick, a couple of 67mm turbos and a heavy foot......... now a best of 9.19 @ 152mph
  1. F.S B series BNIB alum.rad,fuel lines,brake lines
    By teammenace in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 02-06-2008, 12:20 AM
  2. wtb:turbo parts( bov, t3/t4, oil lines, etc)
    By cressida_pimpin in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 02-01-2007, 11:54 AM
  3. Turbo leaking oil out the oil feed.. a Lot of oil
    By b_t in forum Forced Induction Talk
    Latest Threads: 11-28-2005, 02:37 PM
  4. turbo oil lines where to buy?
    By Police in forum Mechanical
    Latest Threads: 01-31-2005, 10:57 PM
