FS: CRX Door panels, CRX Sunroof motor, Prelude hood
***Not pictured is the plastic sunroof visor for CRX 88-91.
I have to make sure I have the hardware for it though, I have the visor but the hardware I have to see where I put it.
$60
you can see on the one door panel it looks like it has a crease along the bottom of the arm rest area.
It seems to be that the material has lifted from the backing of the door in that area.
It's on the lower half of the panel so it wouldn't be seen normally, but I'm sure a person could inject some sort of glue with a syringe to secure it back smooth.
The sunroof motor and everything worked when it was removed, I have the sunroof panel, but it's got rust and you can hear the rust moving around when you tilt it from side to side.
The door panels are $160, and the headliner is $40.
The sunroof motor is $60
Hard to see the hood good, these are the only pics I have of it on the car, pm me for better pics.
Problems with the hood:
Has been repainted, is not factory paint, has some minor rust spots here and there.
It has a bent corner edge, still in tact but it's bent, and will require some minor body work to sturdy it up.
It has the odd dent and ding, but over all it's in ok shape.
$60 for the hood
You must pick up the hood if you're buying it.
"Anarchism is not a romantic fable but the hardheaded realization, based on five thousand years of experience, that we cannot entrust the management of our lives to kings, priests, politicians, generals, and county commissioners."
