long story short.. rushed through my swap.. fucked shit up.. need help fixin.. b18b in eg hahah
anyone mechanically inclined wanna give me a hand? its mainly timing/water pump
poop
You got tools there?
What's wrong with it?
ahh fixed everything...... i hope... im knocking on wood....
poop
Ohh.. Anyone know if setting ur tps to a higher voltage is bad in any way?
poop
Make sure the idle isn't too high an you shouldn't have any problems unless your engine light is on an it's giving a code 7
ive noticed that if i seem to lose power at WOT with the tps currently set to .66+..... anyone know if that does affect it at all?
poop
Do you have a CEL?
nope
poop
Its .5 when its closed and 4.5 all the way open.
i know thats what im sposed to keep it at, im just wondering if theirs any negative effects of it being set high... like i have it set now
poop
Well you said your losing power at WOT maybe change it to .5 at closed throttle an see if your car runs better?
yea i should.. gotta find a multimeter again
poop
Good luck let me know if you need help
Fixed that issue.. Now it still surges during idle and occassionally dies when coming to a stop... Same thing happened to my old engine... Any ideas? I'm thinkin it might have something to do with a shitty ecu..
poop
what ecu are you running?
stock pr4
poop
