Project 2jz-Gte powered S14 - Page 23 - Beyond.ca - Car Forums
Page 23 of 24 FirstFirst ... 13 22 23 24 LastLast
Results 441 to 460 of 479
Thread: Project 2jz-Gte powered S14
  1. #441
    missy
    Oh snap lol, that looks nice fugger. Keep up the good work
    CNC Guru*
    * This is not an advertisement or porn..... but pm me lol
    Instagram: goreski_rdd
  2. #442
    Dec 2007
    Airdrie Alberta
    3.0L Of pure turbocharged testosterone
    Not much of an update, but a bit anyways.
    Set up a usb panel mount, so i dont need to have my cable hanging from the haltech all the time
    Installed the switch to enable my 2 step limiter. POP POP!!! (community reference)
  3. #443
    Dec 2007
    Airdrie Alberta
    I dont know how i fucked up, but ive lost most of my oil pressure. Maybe co-incidence...so...must fix.
    Oh, whats this?
    Oh, and also this........ on the top
  4. #444
    Jul 2009
    Awesome build!
    I wish I kept my S14 haha
  5. #445
    Dec 2007
    Airdrie Alberta
    Finally got around to working on my build.
    Had the block decked, honed, and cleaned. Got new factory bearings, and piston rings.
    Today got the clearances double checked and the crank in and buttoned up. Currently gapping the rings, should be putting in pistons and rod bearings tomorrow.
    PERFECT!!
    Checking for crankshaft thrust, it was perfect FSM measurement at .022mm
    More to come lads, head will get built up next. Im going VVTI for this year, should really help my spool out...not to mention the EFR
  6. #446
    Dec 2007
    Airdrie Alberta
    Pistons/rod bearings in. All thrust measurements are perfect spec, all oil clearances right in the middle. Gapped the rings much more than factory. Thanks for the advice Toma.
    Head work starts next week hopefully. Need to strip it down and get it to precise to be planed. I'll probably re-lap the valves, and do a set of BC springs and Ti retainers. Top it off with a pair of titan 272 VVTI cams and call her a day.
  7. #447
    Beauty. Nice progress.
  8. #448
    Feb 2006
    87 FC3S with JZ power
    PM me if your non vvti head is available.
    Your project looks like it's coming along nicely. Keep up the good work !
  9. #449
    Dec 2007
    Airdrie Alberta
    PMD
  10. #450
    The depths of despair!
    Anything topless.
    Looking good bro. Thinking you'll be done before I get mine up and running!
    WTF!! I am a moderator!!
  11. #451
    Aug 2008
    USE20
    Originally posted by sr20s14zenki
    Is it just me or when you scroll down on this picture it looks like a .GIF and its coming out at you?
    Either way, looks good
  12. #452
    Dec 2007
    Airdrie Alberta
    It's coming to get you. =)
  13. #453
    Dec 2007
    Airdrie Alberta
    Got some junk done.
    GSC springs and retainers transferred over. Old head is obliterated, as were the cams =(
    Pans on, head on. Excuse the mess.. lol
    Waiting on cams. Decided to go mild, just some poncams for this year. When they get here, i can finish assembly and drop it in.
  14. #454
    Dec 2007
    Airdrie Alberta
    I REALLY like this wrinkle paint. Very cool
    Engine as it sits. Need cams, and an O-ring for my water pump. Then the rest can go together.
    Also, found the culprit from last year. SAND!!!!.
    Fucking powdercoaters, i knew they got sand in there....the fittings that i welded on were beat to shit. I should have drilled the rivets and removed the baffles to clean. Oh well, no sense living in the past.
  15. #455
    Dec 2007
    Airdrie Alberta
    Cams ordered...http://www.briancrower.com/makes/toyota/2jzge.shtml
    got the stage 3 272 degree.
    Did a bit more work, fit the turbo for lines, etc.
    Billet titanium tensioner arm
    Factory oil cooler installed. Less complicated (=
  16. #456
    Dec 2007
    Airdrie Alberta
    Decided to paint valley cover white to match car. Lets see how it looks
    Lines all set up. Just waiting on cams now. =(
  17. #457
    Dec 2008
    Alberta
    a really big tow vehicle
    That's a pretty engine! I just bought a 1j gz21 soarer, this build thread gives me plenty of gumption to get modding it!
    1999 NBS Silverado 4x4 awaiting an extensive build.
    6" BDS Lift is in. 37" mud grapplers. Built trans(by me) 4.10's, shaved ls6 heads, comp cam. More to come.
  18. #458
    Dec 2007
    Airdrie Alberta
    Another shot with vc and cover.
    Fit my new bumper. Just needs paint now. Woo
  19. #459
    Dec 2007
    Airdrie Alberta
    Engine prepped for drop in, wiring attached.
    In the car
    Had to mod a pipe. Niiice
    All set up!
    Aaaand running. Such a nice idle for 272 cams.
    http://vid163.photobucket.com/albums...ps6iuzmkhe.mp4
  20. #460
    looking good
    HKS T04Z Bridgeport FD3S
  1. FS: 1992 Toyota Aristo V (2JZ-GTE) **SOLD**
    By jdmsource in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 07-19-2007, 02:15 PM
  2. 2JZ-GTE Inside!...pics of my new car
    By DC2 in forum Cars, Bikes, Machines
    Latest Threads: 06-30-2007, 08:36 AM
  3. Replies: 6
    Latest Threads: 10-18-2005, 01:07 PM
  4. 2jz-gte shortblocks
    By Lurscher in forum Mechanical
    Latest Threads: 02-26-2005, 11:03 PM
