I am selling my SR-6003 Marantz receiver that is about a year and a half old and my SR-8002 which is about 2 years old. They are an excellent product and I have no complaints. The sound quality on these products is vary high end and the SR-8002 is an excellent Audio piece that I was using in my theatre and the SR-6004 is running my system on the main floor. Anyone that knows the Marantz line knows the quality of these products and the detail in which they replicate the audio to the way it is supposed to sound. I have just purchased a new SR-7005 to replace my SR-6003 and an AV-8003 pre amp to pair with my Parasound amps to replace my SR-8002.
I have both products running my systems still as I am waiting for my new products to show up in a week or two. i figured this is the best way to do it so if anyone wants a demo to make sure the products work and sound great they can have a listen.
SR-6003 $650 obo and it has 2 years warranty left as well.
SR-8002 $800 obo and it has a year left on warranty
I have attached specs on both these units below. Sorry the lists are long but if you need any additional information please let me know
Thanks
Jamie 403-703-9587
[email protected]
Marantz SR6003 specifications
General
Product Type AV receiver
Width 17.3 in
Depth 15.3 in
Height 6.3 in
Weight 29.1 lbs
Audio System
Sound Output Mode Surround Sound
Built-in Decoders DTS 96/24 , DTS-ES Discrete 6.1 , DTS-ES Matrix 6.1 , Dolby Digital Plus , DTS Neo:6 , Dolby Pro Logic IIx , DTS-HD Master Audio , Dolby Digital EX , DTS-HD High Resolution , Dolby Digital , Dolby TrueHD
Audio D/A Converter 24bit / 192kHz
Surround Sound Effects Dolby Headphone , Dolby Virtual Speaker , SRS Circle Surround II
Equalizer Yes
Digital Sound Processor (DSP) Yes
Surround System Class 7.1 channel
Response Bandwidth 8 - 100000 Hz
Signal-To-Noise Ratio 105.0 dB
Input Impedance 47.0 KOhm
Input Sensitivity 180.0 mV
Amplifier Output Details 100.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.08 % - 7.0 channel(s) ( Surround ) , 125.0 Watt - 6.0 Ohm - 20 - 20000 Hz - THD 0.08 % - 7.0 channel(s) ( Surround )
Timer Sleep
Bass Control Yes
Treble Control Yes
Built-in Display Fluorescent
Display Dimmer Yes
Additional Features Upgradeable firmware , HDCD decoder , XM satellite radio ready , Source direct , Sirius satellite radio ready , Auto sound calibration , Multi-room audio output , A-B speaker switch , Gold plated connectors , On-screen display
Connections / Cables / Slots
HD connectors HDMI connection(s) on this receiver make it a great choice for your High-Def home theater. One cable carries digital audio and video data directly to your display.
Signal Processing Features
HDMI Switching Yes
HDMI Repeater Yes
Video Conversion/Scaling S-Video to component video conversion , Composite video to component video conversion , Analog to HDMI up conversion , HDMI to HDMI scaling , Composite video to S-Video conversion
Upscaling via HDMI Up to 1080p
Equalizer
Equalizer type Digital graphic
Equalizer band qty 9 bands
Connectors
Headphone Jack Yes
Coaxial Digital Input Yes
Optical Digital Input Yes
Optical Digital Output Yes
Radio
Type Radio tuner - AM/FM - Digital
Tuning Display Fluorescent display
Antenna Form Factor Loop AM / wire FM
Signal-To-Noise Ratio 75.0 dB
Additional Features XM satellite radio ready , XM HD Surround Sound
Digital Player (Recorder)
Type Digital player
Supported Digital Audio Standards AAC , WMA , MP3 , WAV
Additional Features USB flash drive playback
Remote Control
Remote Control Universal remote control - Infrared
Features Learning , Back-lit buttons , Multi-brand compatibility
Connections
Connector Type 1.0 x Component video output ( RCA phono x 3 ) - Front , 2.0 x HDMI output ( 4 pin mini-DIN ) - Front , 2.0 x SPDIF input ( 19 pin HDMI Type A ) - Front , 1.0 x Monitor output ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video output ( 9 pin D-Sub ) - Front , 1.0 x SPDIF input ( RCA phono x 2 ) - Rear , 1.0 x Monitor output ( RCA phono ) - Rear , 4.0 x Headphones ( RCA phono x 2 ) - Rear , 2.0 x Component video input ( RCA phono x 3 ) - Rear , 1.0 x HDMI input ( RCA phono x 3 ) - Rear , 1.0 x Audio line-in ( RCA phono x 8 ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 8 ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 2 ) - Rear , 1.0 x S-Video input ( 4 pin mini-DIN ) - Rear , 2.0 x Speakers output ( 4 pin mini-DIN ) - Rear , 9.0 x SPDIF input ( RCA phono ) - Rear , 4.0 x Serial ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( 19 pin HDMI Type A ) - Rear , 3.0 x 7.1 channel audio line-out ( Banana/spade x 2 ) - Rear , 1.0 x Remote control ( RCA phono x 3 ) - Front , 2.0 x 7.1 channel audio line-in ( RCA phono x 2 ) - Rear , 1.0 x Audio line-out (multi zone) ( 4 pin USB Type A ) - Rear , 3.0 x USB - Rear , 1.0 x S-Video input - Rear , 1.0 x SPDIF output - Rear , 3.0 x Audio line-out - Rear
Miscellaneous
Included Accessories FM antenna , Auto calibration microphone , AM antenna
Power
Power Device Power supply - Internal
Power Consumption Operational 600.0 Watt
Power Outlets 2 AC outlets
Part Number:SR8002
General
Width 17.3 in
Depth 15.6 in
Height 7.2 in
Weight 33.1 lbs
Enclosure Color Black
Enclosure Material Metal
Audio System
Built-in Decoders Dolby Pro Logic IIx ,
DTS-HD decoder ,
Dolby Pro Logic II ,
Dolby Digital ,
DTS decoder ,
THX Surround EX decoder ,
THX Select 2 ,
DTS-ES decoder ,
Dolby Digital Surround EX ,
DTS-ES Matrix 6.1 ,
DTS Neo:6 ,
Dolby TrueHD ,
DTS 96/24
THX certified Yes
Surround Sound Effects SRS Circle Surround II
Signal-To-Noise Ratio 105 dB
Input Channel Qty 8
Output Power / Total 875 Watt
Input Impedance 47 KOhm
Input Sensitivity 168 mV
Amplifier Output Details 125 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08 % - 7 channel(s) ( Surround ),
160 Watt - 6 Ohm - 20 - 20000 Hz - THD 0.08 % - 7 channel(s) ( Surround )
Built-in Clock Sleep timer
Timer Sleep
Bass Control Yes
Treble Control Yes
Display Dimmer Yes
Additional Features THX Select2 certified,
A-B speaker switch,
Source direct,
On-screen display,
Upgradeable firmware,
Multi-room audio output,
HDCD decoder,
Gold plated connectors,
HDMI Switching Yes
HDMI Repeater Yes
Video Conversion/Scaling Composite video to S-Video conversion,
Analog to HDMI up conversion,
S-Video to component video conversion,
Connectors
Headphone Jack Yes
Coaxial Digital Output Yes
Radio
Type Radio / HD radio tuner - AM/FM - Digital
Tuner Frequency Range AM: 520 - 1710 KHz,
FM: 87.5 - 108.0 MHz
Preset Station Qty 60
Signal-To-Noise Ratio 75 dB
Total Harmonic Distortion 0.08%
Additional Features XM satellite radio ready,
Microphone
Type 7
Remote Control
Features Back-lit buttons,
Learning,
Multi-brand compatibility,
LCD display
Connections
Connector Type 4 x HDMI input ( 19 pin HDMI Type A ) - Rear,
2 x HDMI output ( 19 pin HDMI Type A ) - Rear,
3 x SPDIF input ( RCA phono ) - Rear,
3 x SPDIF input - Rear,
1 x SPDIF output ( RCA phono ) - Rear,
1 x SPDIF output - Rear,
1 x 7.1 channel audio line-out ( RCA phono x 8 ) - Rear,
1 x 7.1 channel audio line-in ( RCA phono x 8 ) - Rear,
4 x Component video input ( RCA phono x 3 ) - Rear,
2 x Component video output ( RCA phono x 3 ) - Rear,
4 x Composite video/audio input ( RCA phono x 3 ) - Rear,
2 x Composite video/audio output ( RCA phono x 3 ) - Rear,
1 x Monitor output ( RCA phono ) - Rear,
1 x Monitor output ( 4 pin mini-DIN ) - Rear,
4 x S-Video input ( 4 pin mini-DIN ) - Rear,
2 x S-Video output ( 4 pin mini-DIN ) - Rear,
2 x Audio line-in ( RCA phono x 2 ) - Rear,
2 x Audio line-out ( RCA phono x 2 ) - Rear,
2 x Audio line-out (multi zone) ( RCA phono x 2 ) - Rear,
1 x Composite video output (multi zone) ( RCA phono ) - Rear,
1 x Remote control ( RCA phono x 2 ) - Rear,
1 x System components control bus ( RCA phono x 2 ) - Rear,
11 x Speakers output ( Banana/spade x 2 ) - Rear,
1 x Headphones - Front,
1 x S-Video input ( 4 pin mini-DIN ) - Front,
1 x Composite video/audio input ( RCA phono x 3 ) - Front,
1 x SPDIF input - Front
Miscellaneous
Included Accessories FM antenna,
AM antenna,
Cables Included 1 day(s) x Power cable
Power
Power Consumption Operational 780 Watt
Manufacturer Warranty
Service & Support 3 years warranty
