When/If at all will Alberta get E85? - Beyond.ca - Car Forums
Results 1 to 20 of 34
Thread: When/If at all will Alberta get E85?
    Feb 2003
    2011 GTR
    Default When/If at all will Alberta get E85?
    A lot of the forums I am on, I am noticing a lot of people running E85 and it got me thinking about when if at all Canada or Alberta to be specific, will ever get this. I did a bit of Google searching but didn't find any solid answers so maybe some of my fellow Beyond members know more.
    I would love to get it just so I could push the Evo to its power limits. As guys are making 400-415whp with the Evo X and the stock turbo and even the bigger turbos they are able to get CRAZY! fast spool up out of them with the benefit of turning the timing way up.
    Anyway let me know if you know any more to add to this.
    Garage
    - 2011 GTR
    - 2013 STi
    - 2015 Yamaha FZ07
    Dec 2008
    Airdrie
    PA-20,R65ls
    Gay, my 1950's airplane fuel system cant handle the ethanol!
    Nov 2004
    It doesnt make sense for companies to sell E85 here because I dont think the canadian goverment subsidizes corn crops for the production of ethanol. It doesnt make sense for anyone to sell it here because it costs quite a bit to produce and yields low energy (yes it has a high octane rating)
    May 2005
    Well you could get a 55 gallon drum of E85, cheaper than race gas. Better yet E98. I'm pretty sure a shop in Calgary sold these.
    I know I've said this before, but do you feel comfortable pushing 400-415whp on your tranny? Might be an expensive bill...
    Bicycle
    Is there study shows that E85 performs better than E10 or normal gas?
    Everywhere I read that you should avoid ethanol like a plague unless it's not your daily driver.
    I think local BMW dealerships have told many to avoid Husky/Mohawk's E10.
    E85 has less energy than traditional pump gas. It does have much higher knock resistance, therefore you can run much higher boost/compression ratios without detonation. It's shitty for NA cars.
    Fuel economy is brutal as well, since cruise AFR's is at a whopping 10:1 vs 14.7:1 for normal gasoline.
    It's a poor fuel to use for street applications. It's not even that much cheaper, so overall cost is higher for E85 vs 91 octane in the US due to the reduced fuel economy. The only advantage is political, as it lessens US reliance on foreign oil.
    As for E10 (Husky 94) on normal cars, most of the problems comes from the fact that it throws off O2 sensors, and the measured AFR is incorrect. Cars won't be able to compensate perfectly and you end up with rougher idles, lower power, high EGT's and all sorts of other minor symptoms. This is why the limit for pump fuel is 10% ethanol, cars are designed to work within this range.
    Flex fuel vehicles that support Exx fuel have a Fuel Quality sensor that can measure the ethanol content in the fuel and compensate accordingly.
    Sep 2002
    BoostLand
    something green
    I think its not been rolled out here also because of its poor cold start characteristics. Even in the warmer states, they knock it back to E70 or 75 for winter for cold start reasons. There are times here when you would have to plug in the vehicle all the time to get it to start. No leaving an E85 car in parking lot all day long at -20 even. The increased use of electricity to keep every car plugged cancels out any kind of green benefit.
    As for the E10, I think it tends to have a higher affinity for moisture than pure gasoline, its probably holding a lot more water which makes cars run rough.. I have seen straight 91 make more power and produce less knock than the 94 E blend on the dyno.
    Too loud for Aspen
    Feb 2003
    2011 GTR
    Oh yea I wouldn't think twice about pushing 400whp on the tranny. There are big leaps in tuning for the SST now and lots of people are pushing the 400-450whp levels now. It's the torque they are keeping somewhat low and normally I see these people putting out around 370wtq.
    All the guys on the Evo forums are showing MUCH faster spool up times and between 50-60hp more over a 92/93 octane tune. But at a cost of terrible gas milage. But this issue is easy depending on how you are tuned. With a COBB AccessPort you can just switch from a E85 tune back to a normal gas tune within a few seconds. To run E85 though you need to change out the fuel pump/injectors (at least for the Evo X anyway).
    I wouldn't say it's a poor fuel for street use, it would depend on the vehicle.
    And you couldn't use this on just any car which is why it is causing 02 sensor issues. you either have to have a car built for it (flex fuel vehicles from GM) or in my case change out your fuel pump/injectors and disable the 02 sensor or just remove it as I have done anyway when I went to a test pipe.
    This I could see being a good reason for it not to come here. Didn't think about this haha I was to focused on the performance gain
    Garage
    - 2011 GTR
    - 2013 STi
    - 2015 Yamaha FZ07
    Cochrane, AB
    Trucks
    All gas stations are up to 10% ethanol now for 87 octane.
    Oct 2006
    Nothing
    Hopefully never - screw ethanol.
    May 2007
    Its available in Ontario, but that's probably due to so much corn being grown there, multiple ethanol plants, and government grants for ethanol production. I don't see a fuel ethanol plant being built in AB/SK when they could build something O&G related and make more money :/
    Jun 2006
    Which is good! Range would be horrible on E85.
    Cochrane, AB
    Trucks
    Sounds like the ethanol plant in Vegreville started construction so maybe E85 will be for sale in AB in a few years.
    Oct 2007
    TX
    Camaro 2SS
    Octane rating isn't related to energy content...
    Jan 2012
    Its not a o2 sensor problem, its a fuel trim problem. E85 has less energy than gas. The pcm is programmed for gas, so when you put e85 in the pcm is trying to keep afr to what it is programmed for. Since its lower energy the pcm has to bump up injection pulse to keep up. Once fuel trim hits +25% it will throw a lean code.
    Flex fuel is a industry standard not just a gm thing. Gm is just the only one that is having problems with there alcohol sensors.
    You also have to keep in mind your evo has plastic fuel lines, your going to have to replace them also. Imo its a total wast of money when you dont have the supporting mods. Just turning up the boost is not a safe way of making power.
    Cochrane, AB
    Trucks
    Imo its a total wast of money when you dont have the supporting mods. Just turning up the boost is not a safe way of making power. [/B][/QUOTE]
    No, but being able to throw away your intercooler and adding more timing is the benefit with his fuel.
    Dec 2007
    Airdrie Alberta
    You need to upgrade most fuel pumps and injectors to run e85 as well (excluding gm vehicles that are set up for flex fuel). Injectors and pumps need to be sized 42% bigger than you would size for a gas application. So instead of lets say having an inline 6 making 600 hp on 750 cc injectors on gasoline, you would need 1100 cc injectors. Also, it would increase demand on the fuel pump, so where a nice deutschwerks 340 lph fuel pump would do you well, not so good now.
    e85 is cool, but things need to be alot bigger to support it....so in the end, gasoline is a much more efficient per volume fuel....imo more beneficial to run a meth kit or something instead.
    heres an interesting article.
    I have a magazine somewhere around with a breakdown on e85 requirements
    http://forums.turbobricks.com/showthread.php?t=73061
    Mar 2005
    Pushbroom
    Just run 100 Leaded AVGAS.
    Works great for me! (My car is built and tuned for leaded gasoline.)
    Seriously though, Husky 94 should be good enough.
    Jan 2012
    No, but being able to throw away your intercooler and adding more timing is the benefit with his fuel. [/B][/QUOTE]
    E85 will not cool the intake charge enough. It will detonate like a bastard if you cut out the intercooler. To run a decent boost pressure with no intercooler you will need methanol injection. that is not practical for street use.
    A stock pcm will not advance the ignition timing enough to take advantage of the extra octane. If you have a engine that is built for some good power with good electronics you will make more with e85.
    Cochrane, AB
    Trucks
    Well, anyone with a serious setup will rejoice when E85 is available. E85 vs race fuel is a no-brainer. Not much benefit otherwise.
  1. E85/E98/E99 whole sale?
    By redmethods in forum General Car/Bike Talk
    Latest Threads: 04-18-2012, 10:15 PM
  2. FS: RPI GT Exhaust for E86/E85 BMW M Coupe or Roadster
    By Impreza in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 11-18-2009, 02:07 PM
  3. Revolution Dyno on E85!
    By Ron@Revolution in forum General Car/Bike Talk
    Latest Threads: 09-13-2009, 10:03 PM
  4. WTD: E85/ Z4 performance parts
    By Graham_A_M in forum BMW Marketplace
    Latest Threads: 04-10-2008, 01:26 PM
  5. Jay Leno E85-powered Corvette C6RS
    Latest Threads: 10-29-2007, 07:58 AM
