On my 2003 Denali the CEL light went on today, then later starting idling rough, got home plugged in the code reader and im getting 4 codes for the 02 sensors? I cant really see all 4 sensors dead at the same time? Where do I start?
What are the codes for the o2 sensors that you are getting? Even though you are throwing codes, it doesn't mean that the o2 sensors are gone. I threw o2 codes because I was running lean....
131 137 146 157
Sorry 151 not 146
there must be a common power circuit that is either broken or loose causing the codes, check for blown fuses in the engine bay.
Yeah they are all o2 sensor low circuit voltage
I'd check the circuits leading to the sensors, ensure they have the reference voltage and grounds.
i think this is one for the dealer i cant find an issue, but i did find a random ground wire that has fallen off from severe corossion, but i cant find where it came from? it was sitting on the drivers side bottom of the engine, kinda got melted from the exhaust..
that would be the culprit...Originally posted by becks101
6.0? sounds like your running lean, check fuel pressure and clean/replace MAF... sounds unrelated but try it
