Just got the Teg back from a compression test - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: Just got the Teg back from a compression test
    2008 Z06
    Default Just got the Teg back from a compression test
    1 - 175
    2 - 170
    3 - 165
    4 - 170
    phew! rings are still good. Now I know it was the old PCV valve was causing the oil loss + blue smoke at high rpm.
    I guess I also needed new spark plugs so those are in.
    The mechanic said that one of my axle boots are torn and the other is cracked but not leaking. I'm getting those boots replaced soon now.
    Yaaaaaa, no expensive rebuild.
    Current Cars:
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2005 Jeep Wrangler LJ
    1989 5L Mustang
    1990 Jeep Cherokee
    Dirty_SOHC's Avatar
    Dirty_SOHC is offline 0.2 liters away from a good engine
    Jul 2002
    WRX
    Where did you take it and how much was the test.??? I think I may need one done. Thnxs Graham
    2008 Z06
    Ron's Propane Ltd.
    Bay 7,3815 - 61st Ave S.E.
    236-5535
    4 plugs
    comp test
    oil + service
    = $91.00
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    those compression numbers seem pretty high for a ls engine.
    i compression tested my engine with a $50 self tester. some how i got 185psi on all 4. i think i did it worng...
    2008 Z06
    My car has a CR of 9.2:1 !! that's loooooow.
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    9.872604, -85.498802
    Turbos n Stuff™
    Ahaha, mines 8.3:1
    Travel
    Jul 2002
    four-oh-three
    2007 Impreza Wagon
    isn't the stock compression only around 9.6?
    2008 Z06
    nope:
    http://www.g2ic.com/specs.html
    my dad's porsche is 7.0:1
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    6.7 CUMMINS, E50 AMG
    Compression numbers depend on how the test was done, u can get 240 on all 4 cylinders, it just depends on how many times u crank it over. U can still have done rings and get normal compression numbers, theres so much carbon buildup in the cylinders that it shows good compression. I think the only thing a comp test is good for is showing a loss of comprssion in one or 2 cylinders. Like if u blow your engine it could look like 185 185 43 185. A blown head gasket could look like 175 175 132 175.
    2008 Z06
    I just found this too:
    "You can have good compression and still be blowing tons of oil through the rings.
    There are 3 sets of rings on your pistons...
    Compression Rings
    Oil Control Rings
    Oil Scraper Rings
    I am way too tired to go into detail of how each of them work, but they each do their own part in making the bottom end of your engine work right.
    I have a 91 LS with 180 all the way across on my compression test and I am still blowing through 1-2 quarts of oil every week."
    If I am still using oil, I'll get a leakdown test to ID the source.
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    A leakdown test is about as good as a compression test , if ur burning oil at high revs ur rings are shot, if u burn oil when u start the car up its your valve seals, The only way to be sure is take your engine apart and measure the tolarances!
  1. low boost w/ med compression vs. high boost w/ low compression?
    By Ekliptix in forum General Car/Bike Talk
    Latest Threads: 11-14-2002, 08:12 PM
  2. what do you look for in a compression test?
    By 2000impreza in forum Mechanical
    Latest Threads: 08-20-2002, 03:04 PM
  3. I got my rims back!!
    By Pete92SL in forum Cars, Bikes, Machines
    Latest Threads: 07-18-2002, 03:54 PM
