No heat when idling - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: No heat when idling
    Sep 2005
    Default No heat when idling
    Quick question for those in the know:
    When idling/at a stop light my car stops blowing warm air, and begins to blow cold air. In addition to this, the car really isn't blowing hot air when it should - just a 'luke warm' air.
    Any idea what the problem could be?
    *Last year the timing belt/water pump was replaced - could the coolant be the issue?
    The car is an '06 Acura TL...
    Fiesta ST
    Low coolant or an air bubble in the lines somewhere. Idle the engine with the coolant system open to atmosphere for 5-10 mintues, then top up if necessary.
    Dec 2008
    Also could be a t-stat, does the car take a long time to get up to temp? Only other thing I can think of is a water pump, but if it was a water pump chances are you'd notice temp fluctuations (ie would probably get really hot in stop and go traffic). My guess out of the two would be a t-stat
    Sep 2005
    hmm...if it was the t-stat, wouldn't it stay cold for a longer period of time?
    (No idea, myself)
    Blitz - by keeping the cooling system open, are you referring to keeping the radiator cap open?
    AB
    16' Tacoma Offroad
    Start with coolant level.
    Dec 2008
    (No idea, myself)
    Yea it would stay cold for a long time and you may never get hot air blowing through your vents. He means keeping the overflow/expansion cap off. However I would consult a manual first, this was how you used to do it but my VW service manual does not recommend this, also most t-stats on newer cars can bleed air past them so they will still open and you'll get flow but blitz is right a giant air pocket could give you similar symptoms.
    May 2007
    92 Civic-t, 01 VW Golf TDI
    check your rad cap pressure to see if thats holding up, check coolant, what color is it? is the vehicle heating up to normal temp? did they put the right stuff in after the t-belt? measure/feel your heater core inlet and outlet temperatures
    if all is good then my best guess is an issue with a blockage in your heater core, minimal flow at idle means the heater fan is stripping the heat faster than new coolant can be delivered in, if so then try a backflush (disconnect heater core and apply a garden hose to the outlet) be carefull not to apply too much pressure and cause a leak in your heater core
    Jul 2006
    Victoria Park
    Yep it could be the thermostat. Easy fix if so.. (Happened to me, no warm air when stopped).
    Other than that, coolant flush.
    Jul 2006
    NA
  1. which is cheaper turning up heat or a portable heat
    By 95EG6P in forum Home and Garden
    Latest Threads: 03-06-2014, 09:40 PM
  2. FS: Heat, heat, Bathing ape, Baby Milo, Artful Dodger...
    By Redlyne_mr2 in forum Fashion and Apparel
    Latest Threads: 06-09-2009, 04:59 PM
  3. Mazda Protege shaking/idling problems
    By Heddi in forum Mechanical
    Latest Threads: 05-14-2004, 03:17 PM
  4. Idling FACTS from the C.A.A
    By haze4dayz in forum General Car/Bike Talk
    Latest Threads: 02-15-2004, 01:44 AM
  5. firefly idling problem
    By curt234 in forum Mechanical
    Latest Threads: 11-19-2003, 02:56 PM
