Need help diagnoseing my camry - Beyond.ca - Car Forums
Results 1 to 15 of 15
Thread: Need help diagnoseing my camry
    Nov 2005
    A Slow Car
    Unhappy Need help diagnoseing my camry
    I have a 94 camry 2.2 4 cyl. When i start the car in the morning it starts than sputters and shuts off. I have to hold the gas pedal down for 1/2 min so it would stay on. I took the car to my mechanic and he couldn't do anything because there is no check engine light on. I did clean the IAC valve and it didn't help.
    Help would be highly appreciated.
    Thanks.
    “Straight roads are for fast cars, turns are for fast drivers.”
    Default Re: Need help diagnoseing my camry
    Wow really? My advice. Get a new mechanic first.
    Nov 2005
    A Slow Car
    This is the second mechanic telling me that.
    Jun 2007
    Medicine Hat
    MY97 WRX
    Definitely go to a new mechanic. Just because a CEL isnt on does not mean something doesn't have to be replaced/fixed
    Show up to these shops without brake pads on and say youre having troubles stopping, think they will say they cant diagnose the vehicle because the CEL isnt on?
    Customer: "I cant shift into gear, when I try to put it into first it grinds, and there is a burning smell. I think I need a new clutch"
    Mechanic: "Sorry I checked the computer and there is no code. I guess the car was designed like that."
    Nov 2005
    A Slow Car
    LOL you guys know a good place to take my car in?
    The dealer?
    just a thought... they might know those vehicles.
    AB
    16' Tacoma Offroad
    Most obd1 cars will not trigger a light unless its a complete failure.
    Those 5SFE's have cold start injectors to help them in the morning and is the first point of interest I would look at. I would also inspect the distributor cap/rotor for wear.
    I doubt many dealer techs work on pre 2005 vehicles anymore but I'm sure there's still some seasoned mechanics at the established dealers.
    Calgary/Alberta
    00 Protege
    Does the vehicle have EGR?
    If it does this can cause a stall at cold start or idle if it's stuck open. You can try cleaning that as well.
    Any other issues in terms of idling? Idles smooth warm or does it still bounce.
    Could you have stuff stuck in your iacv from when you cleaned it.
    Guy should have at least tried to duplicate the issue; it's guys like this that make a bad name for the rest of us. If a vehicle is intermittent you just use some common deducing as to which direction to go from the customers complaint while staying within a reasonable duration of diagnosis time.
    Best of luck.
    There still might be a code somewhere in the system. Not all problems result in a CEL.
    For instance, I drive around with a OBD scanner (ScanGauge II - also shows fuel consumption in hours) hooked up to my ECU and it throws the same code (P1298) every time I start the car - yet no CEL ever comes on.
    Mar 2008
    https://t.me/pump_upp
    /85' Corolla GTS AE86 - 20V /06' X-Runner
    If you still don't have a good mechanic - bring it to us at Garagebox Auto Innovations - call us on Monday at 11! 403.984.2808.
    Ray
    Dec 2004
    YYC and YVR
    First thing - get a new mechanic like everyone says. Your current mechanic is lazy, and you don't want people like that working on your car.
    Have you checked your fuel pump and/or ignition coil? It sounds to me like it could be one or the other or both.
    Could also be the MAF sensor. Check the vacuum going to it?
    Nov 2005
    A Slow Car
    Took it to a reputable shop and explained the situation to him and right away he told me that it's my IAC valve. Told me the buy the part which is expensive but you can buy refurbished or used from the wreckers. I guess i found a new mechanic
    But i appreciate all your help guys
    Mar 2007
    1996 Buick Regal GranSport
    which shop was this i need to start going there
    Nov 2005
    A Slow Car
    This one
    Friend of mine told me to take it there...I guess they're well known cuz it was pretty busy.
  1. FS: New Eibach Camber kit for Camry, OEM 95 Camry 4cyl springs
    By RedRocketDX in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 05-06-2007, 09:17 PM
  2. Camry Headlight Help
    By soupey in forum Cosmetic and Styling Modifications
    Latest Threads: 12-20-2005, 10:07 PM
  3. 89 camry popping noise Plz HELP!
    By 777Rx7RRR in forum Mechanical
    Latest Threads: 07-04-2004, 07:32 PM
  4. 1988 Toyota Camry For Sale
    By max_boost in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-14-2002, 11:29 PM
