1600? obo
Like I said in my post TRD syncros, TRD differential , TRD upgraded gears from a solara
I assume this is an e153 for an 91-95 MR2? What year/mileage car did this come out of if you know? I'm not aware of TRD Synchros for the e153. I also am not aware of a TRD Gearset for the e153. Do you have part numbers? Do you have the documentation from the rebuild? the receipt?
If also mention Solara gears, can you clarify which gearset and final drive combination is installed?
Thanks,
Ryan
The problem with socialism is that you eventually run out of other people's money. - Margaret Thatcher
BUMP PRICE IS OBO will include a TRD shifter assembly or a B&M your choice
Did I miss a PM or did you just ignore all my questions?
Hey man i sent you a PM, ill respond in here aswell..
Yes Correct E153
From a 93 motor set Tranny has probably seen 40xxxkm on since rebuild, I dont have part numbers as i didnt build it previous owner did, refurbish was done at heninger years ago i have receipts showing the overhaul done on it but no part numbers.. Im going strictly off of what previous owner told me..
Hope that helps..
-Rhys
I don't see synchros on this list: http://trdparts.jp/english/list_mr2.html
Doesn't mean they didn't exist, TRD had some parts that were hard to find listed, I believe. Just means they were likely hard to find.
