Vehicle Details
Year : 1994
Make and Model : Acura Integra RS
Exterior Color : Black
Interior Color : Tan
Auto or Manual? : Manual
Odometer Reading : Body 240,XXX. Engine <10,000km
Location of Vehicle : Calgary, AB
Description : Looking to start a different project, something RWD and preferably Toyota.
That being said I am open to offers/trades + cash or whatever is out there. This is a PERFECT project car.
Asking Price : $13,000 or $10,000 w/o V-Pro and AFK FIRM, Open to trades also.
Cons: Rear quarter rust, Needs new tires (rears are decent), Needs new coilovers/shocks.
Interior needs some work just old etc, Has 3 broken exhaust manifold studs (just sweats exhaust gas though).
Somebody tried to break into it, leaving a dent the size of a CD on the passenger side near the door.
Power Steering is not hooked up, the hose is broken at the fitting (just removed the belt).
Pros:
-Laskey Racing custom built motor, capable of 700+whp!
-287whp/256wtq (Low Cam, 7000rpm break in tune)
-Brand new windshield.
- $20,000+ in receipts.
Engine: B20B4 w/ GSR Head
Benson Signature Series Block - B20B4 (Sleeved w/Bensons exclusive 50psi sleeves.)
84mm CP 9:1 Pistons
Eagle Rods
Benson micropolished and balanced crank (spun to 11,000RPM)
OEM ITR Oil Pump
OEM ITR Water Pump
OEM ITR Flywheel
B18C1 Head
ACL Bearings
GSR Cams
ITR Valvetrain
Skunk2 Intake Manifold
Hondata IMG
Cometic MLS Headgasket
ARP Headstuds, Mainstuds and Rod Bolts
MFactory Magnetic Oil&Trans drain plugs
HKS SSQV
HKS IAT Sensor
HKS 4bar Map Sensor
Turbosmart Wastegate
Garrett T04E Hybrid Turbo
Legendboy tubular manifold
OEM Type R Valve Cover
NGK Spark Plug Wires
Siemens 890cc Injectors
Walboro 255LPH Fuel Pump
Transmission:
ITR Transmission
Kaaz LSD
Syncrotech 1st-5th gear Carbon Synchros
ACT 6 Puck Clutch and Xtreme Pressure Plate (408ft.lbs)
Brakes:
Wilwood Big Brake Kit
Wilwood 2 Piece Rotors
Wilwood Stainless Steel Lines
Power Slot Rear Rotors
Hawk HPS Pads
Interior:
Momo Acropolis bucket
Momo steering wheel
Skunk2 Weighted Shift Knob
Stewart Warner EGT Gauge
Stewart Warner Water Temp Gauge
Stewart Warner Oil Pressure Gauge
Electronics:
HKS F-Con V-Pro Ver. 3.3
HKS EVC-S Boost Controller
HKS AFK Wideband
4300K HID's
HKS F-Con V-Pro vehicle specific harness (JDM DC2)
Wheels:
Work Emotion XD9 17x7.5 and 17x8.5
Bridgestone RE050
Skunk2 Open End Forged Lug Nuts
Exterior:
ITR Lip
ITR Wing
Shaved side mouldings and rear valences.
Contact Information
E-Mail : [email protected]
Phone : 403-875-4976
Pictures : I can email/text more recent pictures if requested or if anyone has questions.
$13,000 or $10,000
