Cel - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Cel
    Dec 2004
    Default Cel
    2007 mazdaspeed 3 everything stock expect a mazdaspeed CAI
    i was driving, and did wot when hitting the 4-5k rpm it stutters or bogs, or has some sort of hesitation. going through gears 3 to fourth didnt even go into 5. after that happen a CEL came on?
    anyone has a OBD reader? and can help me out?
    Dec 2007
    Airdrie Alberta
    Sounds like maybe bad plugs..check those first.
    Does it blink the CEL during the stumble?
    Dec 2004
    It did and now it stays on.
    Dec 2007
    Airdrie Alberta
    Yep sounds like misfire. Start by changing and properly gapping plugs.
    May 2007
    Doesn't that sound like a big boost leak on a MAF car to you?
    I'd double check the charge pipe connectors for tightness, and check the CAI for any air leaks post-MAF
    Dec 2007
    Airdrie Alberta
    Sppose it could be that as well. I just said the easiest, most overlooked thing.
    couldnt hurt to clean the maf while you are at it.
    do those plugs tho, cheap and good maintenance
    Dec 2004
    the plugs been changed two weeks ago,
    and the code is p0300 all cylinders mis fire!?!?
    would like some help on checking on these things, i would buy lunch? or a case of beer? i thought it was just bad gas i filled up on
    AB
    16' Tacoma Offroad
    p0300 is random misfire, not all, but can be.
    Often the p0300 is catalyst damaging so if you cannot repair it yourself get a shop to do so before it gets worse.
    If the spark plugs are new and gapped properly I usually start by inspecting the fuel trim and o2 sensor readings. Cylinder Balance test's are good too.
    Dec 2004
    okay, here the sticky part. my friend clear the code by mistake. and i still have warranty on the car. should i tell them to have a look at it?
    Feb 2007
    Calgary, AB/ Toronto, ON
    981 GT4/F82 M4
    I'd put my money on the high pressure fuel pump. Common problem with these cars. Yes, bring it back for them to check under warranty.
    Dec 2004
    okay well i am gonna get new gas in, spark plugs and coilpacks..if that all fails ill check out the high pressure fuel pump last.
    Jan 2012
    It would be cheaper to spend a hour of diagnostic time at a shop than throw parts at it.
    Dec 2007
    Airdrie Alberta
    Here is a test procedure for coil packs, but it doesnt sound like them to me.
    also, make CERTAIN the gaps of the plugs are correct to factory spec, hell, maybe just a bit smaller. It could just be spark blowout from horribly out of spec plugs (i know they were just changed, people make mistakes)
    Also, as mentioned above, checking for leaks, ESPECIALLY after the maf is a good idea....charge pipes do come off from time to time on turbocharged engines.
    if that doesnt check out and coilpacks are in spec, i would get a fuel pressure gauge, and check the fuel pressure.
    Mar 2010
    '16 GMC HD '94 MKIV SUPRA
    I have a code reader at my shop, swing by and I can check/clear the codes!
    Its the lube-X at 12600 Symons Valley RD NW
    (I wont charge you anything to clear them either, Ill be there at 8 mon am)
    Dec 2004
    okay what i have done today.
    i clean the maf all good to go. nothing is loose all hose are tight.
    next will be spark plugs and coilpacks
    Jan 2012
    A p0300 is set when the pcm senses a miss but cannot figger out what cylinder is misfiring. A P0300 can be very shitty to figger out at times.
    The instructions that were posted to test your coil is only for testing the primary side. If there was a problem in the primary coil it would most likley set a cylinder specific code. Most coils that cause problems will pass the ohm test. Really your going to need to scope the primary and secondary sides to pass or fail the coil on this problem. napa sells each coil at $217 each so its a pricey guess.
    If I was diagnosing this problem, the first thing I would do is go into mode 6 and see what the misfire counters are doing and go from there. Your not going to get any good live data or really anything from a code reader.
    Dec 2004
    so i went out for a quick drive just 10 minutes ago. so under WOT
    around 4-5k rpm it just stutters a little bit, then picks up.
    the code threw with it was like -30 out. some forums say something about water getting into the coilpack? if that even possible. if i can get it running right, i will take it in to mazda to check out and pay that diagnostic test.
    Jan 2012
    Apparently, water can drip through the hood scoup and on to the coils that will cause a miss on cold start up.
    Dec 2004
    yeah, damn eh...i am in the hole for this one lol
    May 2007
    92 Civic-t, 01 VW Golf TDI
    Sticking open EGR valve
  1. CEL on after exhaust was installed
    By freakin in forum Mechanical
    Latest Threads: 04-23-2004, 01:24 PM
  2. 1998 Accord EX CEL
    By vc1234 in forum Mechanical
    Latest Threads: 04-17-2004, 03:02 PM
  3. Cel
    By 97GSR in forum Mechanical
    Latest Threads: 02-08-2004, 11:10 AM
  4. CEL after CAI install......
    By ebny in forum Mechanical
    Latest Threads: 06-10-2003, 05:31 PM
  5. TPS Sensor CEL 7
    By Weapon_R in forum Mechanical
    Latest Threads: 05-02-2003, 12:33 AM
