1991 Aquamarine pearl mr2 turbo
Right Hand Drive
115xxx kms
10,000$ OBO
Footwork
WORK XD-9 High endurance black, 17x8.5, 17x9.5
JIC Magic FLT-TAR coil-overs (first production set for a mr2)
Powerslot rotors and Raybestos ceramic pads all around
Willwood 570 Brake Fluid
Power
MyMizu Aluminum radiator
Yamaha 3SGTE Rev 2 Engine
Toyota CT20b Turbo
EMS Powered 3" Downpipe
Stay Cool Heat Wrapping
Stay Cool Zip Straps
EMS Powered Intercooler kit
ATS Racing throttle body inlet
T-Bolt Clamps, and new couplers
ATS Racing Phenolic spacer (TVIS DELETE)
Team Toyota Europe 1.2mm HeadGasket
ARP Head studs
All new exhaust studs and gaskets
HKS super mega flow intake - new filter 2010
Greddy Type S BOV
TRD Short throw shifter
All new coolant lines
HFH, HFHOE done
Valve cover gasket, plug tubes and distributor o-ring
Full tune up done at Toyota.
Compression tested at 180 on all four cylinders.
Timing belt and water pump recently done
Professionally powdercoated valve cover
Rebuilt head by Best Engine Rebuilders
Blitz oil cap
Blitz Rad Cap
New Distributor, plugs, seals, injector seals etc etc etc.
Interior
TRD Shift Knob
*NRG Wheel adapter
*NRG Quick Release
*Nardi Leather Wheel
EMS Powered In cluster digital boost gauge
Innovate wideband, mounted with HKS Column mount
Exterior
3000k HID fog lamps (Yellow)
Tinted windows
Kouki Tailights
The Tire Warehouse / Garage Works Driven 2009 - Best Toyota of Show winner.
The Setup
Car is currently running 10 psi, oem boost.
Car has its throttle body warming system removed, the charcoal can is also removed, there has been a simplification of the vac lines in the engine bay, and also removed TVIS.
Stance! -
- WORK XD-9 in High Endurance Black w/ rubber - 17 x 8.5 + 32, 17x9.5 + 28
- Ichiba 10mm hubcentric spacers and 45mm studs
- Rev 2 spindles (all 4 corners with good wheel bearings)
- Brake Rotors (Powerslot performance rotors, lots of life left)
- Raybestos brake pads in tuned up calipers (new sliders, and seals)
- Earl's stainless steel brake lines
- Crash bolts with a tonne of camber adjustments.
- JIC Magic FLT-TAR coil-overs - in great shape
------->TRD STRUT BAR & ELECTRIC FANS NOT INCLUDED<---------
****PLEASE DO NOT WASTE MY TIME,NO LOWBALLERS OR PEOPLE WAITING FOR CARS TO SELL!! CASH ONLY***TRADES ONLY ACCEPTED IF CASH PUT ONTOP***
Thank You For Your Time And Looking!!!!
LINK TO PICS---->
http://alberta.kijiji.ca/c-cars-vehi...AdIdZ351285048
