I ripped up the old particle board subfloor that was over thi slat flooring.
I have 1/2" plywood as the new subfloor. My issue is that on the outside walls there is a 2*4 running along the edge of the wall. In some spots it is as much as 3/8" higher than the slat floorboards. The slats are level. If i put the plywood to the edge it will not be level.
How do you solve this? I was thinking might have to sand it down all the way around the perimeter which will be a huge pain in the ass. What do you carpenters do?
