Project "Special K"... Lets try this again - Page 13 - Beyond.ca - Car Forums
Page 13 of 13 FirstFirst ... 3 12 13
Results 241 to 260 of 260
Thread: Project "Special K"... Lets try this again
  1. #241
    Apr 2006
    2008 Nissan Altima
    Originally posted by Guglianoh
    Low to mid 400's.
    Careful when using the term "ek", its trolling season
    lol I mean... err... em...EJ6
    picky people lol
  2. #242
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    But that troll is just Errol....
    ...@therealarifjina...
  3. #243
    Apr 2004
    You tell 'em EJ 2.0!
    HKS T04Z Bridgeport FD3S
  4. #244
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    Darn tootin' I will!!!
  5. #245
    Aug 2008
    Benson B20 Turbo EK
    20160312_094928 by Guglianoh, on Flickr
    Following with the theme of this build my Dyno day would not go without some drama... The day started out with some low load, off boost/low cam tuning which ended smoothly, car was running great! We then proceeded with the Vtec tuning, again went smoothly and then onto the on boost tuning. After each short pull we could see EGT climbing up to 1750 F which was quite alarming. AFRs were reading good so more fuel was added to try and lower the temperatures without playing around with the timing. As boost was climbing torque was not following suit and EGTs continued to climb. on the Last pull there was a sudden misfire around 6500 rpm. We pulled the plugs and saw one cylinder was quite lean, swapping injectors carry the lean symptom to the opposite cylinder which lead me to think the injectors were faulty. We ended the day there so i could address my fueling issue before anymore problems came up. The following morning i drove the car in and out of the shop to clean up and she didnt want to start at all. Finally she started and she was sounded like the plugs were severely fouled, i took her for a short trip to try and clear the spark plugs only to flood the engine one block later. My coworker came to my aid with a new set of plugs which we swapped in at the side of the road. She still wouldnt start with brand new plugs... Reaking of fuel i unplugged the injectors to try and clear what was left in the cylinders, sure thing she fired right up.... and kept running.... for 3 blocks! With the injectors completely unplugged i limped back to the shop, i thought for sure the injectors were stuck open. My fuel pressure gauge would drop right to zero PSI when i primed the pump, i drained 1/2L of fuel out of my oil pan... not good. So this happened the following day! New set of Bosch 1000cc EV14 high impedence injectors to replace my ancient Dephi EV1 injectors.
    IMG_20160315_215054 by Guglianoh, on Flickr
    The following night i changed the oil, swapped in the injectors and after having the injector tables tweaked it was time to fire up!.... No start... pulled the plugs and again soaked in fuel! unplug the injectors, again it ran.... Fuel pressure still dropped to nearly zero PSI. WTF!?!?! Long story short this is what i found
    VID_20160316_194629 by Guglianoh, on Flickr
    My brand new Radium fuel pulse dampener less than a week old, failed! in the video you can clearly see fuel spraying out from the vacuum port on top of the unit. Fuel was shooting past the rubber diaphragm, through the vacuum line and into the intake manifold. Talk about TBI lol This is what i found when i opened up the unit
    20160316_200459 by Guglianoh, on Flickr
    20160316_200452 by Guglianoh, on Flickr
    clearly a torn diaphragm, but why? it literally had only seen how ever many kms from my dyno tuning. I contacted the shop were i had purchased the part and they were able to get me a replacement/upgraded part that very day. Apparently this was a known issue which has been addressed with an updated diaphragm, i know have a new diaphragm and upgraded larger housing.
    20160317_180203 by Guglianoh, on Flickr
    the housing was so large that i had to take the top off to install it, with the housing off i could inspect the new diaphragm and notice something that my previous one was missing... a small ball bearing. Jammed on the opposite end of my fuel rail blocking off my fuel return line was the ball bearing from my other diaphragm.
    20160317_183032 by Guglianoh, on Flickr
    20160317_183041 by Guglianoh, on Flickr
    What doesnt kill you makes you stronger? There are a lot of terrible things that could have happened if i didnt address this issue when i did, I am thankful that nothing did. Im trying not to think about those things as i proceed with tuning, Big thanks to Blackbird Technical Service for understanding something was wrong and not over looking it just to finish my tune. Thanks to Vex Performance for sorting out my issue with the pulse dampener same day i really appreciate that. Last but definetly not least a big shout out to JDM Source for being my number shop for last minute OEM parts. Lets try this again shall we? Dyno day round 3 here we go
    Horse power is a lot like sex, you can never get enough!
    http://forums.beyond.ca/showthread.php?s=&postid=3898225#post3898225
  6. #246
    Aug 2008
    Benson B20 Turbo EK
    Bump from the dead:
    Its been a while since my last update, it seems i just cant catch a break with thus build... August of 2016 a nasty hail storm came through my city and destroyed my car. The vehicle was a total loss, damage to literally every single panel of my vehicle.... even on my wheel center caps!
    20170406_105834 by Guglianoh, on Flickr
    IMG_20170624_150942_736 by Guglianoh, on Flickr
    After this i was devastated, the sat... for a while. In late April i crossed something off my bucket list and went to Japan with friends. Our trip was outstanding, beyond words. Fuji speedway, Tsukuba circuit, Wekfest were just a few things we got up to, i cant wait to go back! Haha
    20170504_105455 by Guglianoh, on Flickr
    20170504_122036 by Guglianoh, on Flickr
    20170505_082903 by Guglianoh, on Flickr
    20170505_085603 by Guglianoh, on Flickr
    20170503_120013 by Guglianoh, on Flickr
    20170503_124309 by Guglianoh, on Flickr
    20170427_084836 by Guglianoh, on Flickr
  7. #247
    Aug 2008
    Benson B20 Turbo EK
    When i got back i started working on my car again. One of the biggest problems that plagued my car on the dyno was quickly rising coolant temps. Unfortunately the Full Race exhaust manifold i have places the waste gate right where more radiator could fit, so i had to move it.
    20170510_070806 by Guglianoh, on Flickr
    20170517_080125 by Guglianoh, on Flickr
    An old VW scirocco radiator would do the trick
    20170514_184537 by Guglianoh, on Flickr
    20170514_184312 by Guglianoh, on Flickr
    20170517_185752 by Guglianoh, on Flickr
    While upgrading my radiator i went one step further installing a swirl pot
    20170525_212209 by Guglianoh, on Flickr
    20170525_212316 by Guglianoh, on Flickr
    20170527_195340 by Guglianoh, on Flickr
    20170528_192239 by Guglianoh, on Flickr
    Another issue i had on the dyno was ignition drift. The AEM EPM unit wasnt doing its job. After spot on customer service and tech support from AEM i decided to make my own igntion setup. Already had the OBD2 oil pump which has provisions for a crank sensor so all i needed was a cam trigger, nothing a magnet cant fix
    20170403_180717 by Guglianoh, on Flickr
    20170403_180803 by Guglianoh, on Flickr
    20170403_185741 by Guglianoh, on Flickr
    20170403_180638 by Guglianoh, on Flickr
  8. #248
    Aug 2008
    Benson B20 Turbo EK
    - - - Updated - - -
    Next on the list was to finally use my DC5 brembos that have been collecting dust for years now. 5 lug ftw. While rebuilding my calipers i replaced the pistons with ceramic ones from a porsche cayman
    20170329_183708 by Guglianoh, on Flickr
    20170329_183714 by Guglianoh, on Flickr
    20170329_183716 by Guglianoh, on Flickr
    20170722_183338 by Guglianoh, on Flickr
  9. #249
    Aug 2008
    Benson B20 Turbo EK
    Now i really needed to deal with the body. The hail damage was terrible, 2 PDR specialist refused the job due to the extent of the damage. There was only one answer...
    IMG_2162 by Guglianoh, on Flickr
    IMG_2154 by Guglianoh, on Flickr
    20170605_192411 by Guglianoh, on Flickr
    20170605_191827 by Guglianoh, on Flickr
    Yes that is a M and M hyper wide body kit . I tried so hard to keep this chassis but after the body shops estimate for repairs/body kit fitment and paint it just wasnt logical to keep. Back to square one... with only 2 weeks away from the Illmotion show and shine i was lucky enough to find this really clean shell.
    IMG_20170727_140421_064 by Guglianoh, on Flickr
    - - - Updated - - -
    As i mentioned i only had 2 weeks to complete this build.... the following days are still a blur, the earliest i got home every night was 1am. Time to get to work
    20170727_231218 by Guglianoh, on Flickr
    20170728_123712 by Guglianoh, on Flickr
    20170802_011456 by Guglianoh, on Flickr
    VID-20170802-WA0006 by Guglianoh, on Flickr
    This kit is enormous! My friend 16x8 SSR look miniature in the wheel wells. 18x10 TE37 might do the trick
    20170729_170125 by Guglianoh, on Flickr
    20170814_214455 by Guglianoh, on Flickr
    Time was running short so the only way to make my car one color was vinyl wrap. Im not a fan of wrapped cars, but after seeing how much work is involved i can appreciate the craft
    20170808_154952 by Guglianoh, on Flickr
    20170811_225459 by Guglianoh, on Flickr
    20170811_225443 by Guglianoh, on Flickr
    At 7:45 am morning of the show, i emerged with something resembling a car.
    20170813_070326 by Guglianoh, on Flickr
    20170813_090321 by Guglianoh, on Flickr
    20170813_090258 by Guglianoh, on Flickr
    Resized_MBP_6300001 by Guglianoh, on Flickr
    Resized_MBP_6302001 by Guglianoh, on Flickr
    Huge thanks to everyone that helped me pull off this incredible feat, i absolutely could not have done this alone... or without an unhealthy amount of caffiene haha more pics to come, enjoy!
  10. #250
    Feb 2008
    Not Aspen
    teslo murdel free
    Simply amazing dude. Love the evolution of this build over the years. Mad props
  11. #251
    X5D, Fiesta ST
    New chassis looks great! I think you messaged me about my K20 EK shell when I was selling on kijiji a while ago haha.
  12. #252
    Bunch of Honda's
    Love this car!
    And holy hell is the widebody every WIDE! Massive fenders, love it.
  13. #253
    Jul 2008
    Transnistria
    Exploded.
    I love the color.
  14. #254
    Dec 2002
    the titty bar...
    starts with a screwdriver...
    Nothing beats an old fashioned build thread. Great job and great commitment to your project!
    I MAKE BALLER CARS MORE BALLER.....
  15. #255
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    I LOVE IT AND I LOVE YOU
    SO happy someone I know did this kit so I didn't have to haha...
  16. #256
    Dec 2008
    Unit 91 come in 91
    Quote Originally Posted by EK 2.0 View Post
    But you do know it would look good on a white EK!
    Was able to get a good look at the car on Sunday and was amazed how great it looked. Nice work
  17. #257
    Feb 2006
    Nice flares bro!
  18. #258
    Aug 2008
    Benson B20 Turbo EK
    Quote Originally Posted by Twin_Cam_Turbo View Post
    Probably haha i has trying to find a clean shell
    Love this car!
    They really are! 60mm over fenders, the wheels are 18x10 +30 in the rear i have to run a 25mm spacer to clear the trailing are haha
    Dam the L word.... does that mean we are offically exclusive now? haha
    Thanks guys, ill post more pictures soon i have a photo shoot this weekend. cheers
    IMG_20170816_083449_379 by Guglianoh, on Flickr
  19. #259
    V167
    Well done, looks amazing
  20. #260
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    Quote Originally Posted by Guglianoh View Post
    Yeah I guess that does....
  1. f/s lets try this again! 91 toyota soarer tt
    By iamkorean in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 04-07-2008, 06:58 PM
  2. ok... lets try this again
    By Lilac Wine in forum General Car/Bike Talk
    Latest Threads: 09-25-2004, 06:20 PM
  3. Try This Again - Need 17" tires before spring!
    By Weapon_R in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 01-13-2004, 06:32 PM
  4. ok lets try this again
    By )v(ortal in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-10-2003, 04:03 PM
  5. lets try this again!!
    Latest Threads: 08-22-2003, 04:19 PM
