You can borrow my engine crane, if you would like.
Drop the engine and tranny together out the bottom with two floor jacks.
Done it tons of times.
Lol but how do I lift the body high enough to clear the engine?
Horse power is a lot like sex, you can never get enough!
http://forums.beyond.ca/showthread.php?s=&postid=3898225#post3898225
With a jack! Take the wheels off the back and drop the ass on the ground, it helps.
Hmmmm interesting, well I have arranged to borrow a crane tomorrow so ill just wait haha thanks tho!
LOL still cant get over the fact someone called it the limp dick exhaust LOL
[QUOTE]Originally posted by Sentry
[B]With a jack! Take the wheels off the back and drop the ass on the ground, it helps.
I'm going to try this but my exhaust wont be easy to drop. What do you use on the back end to block it up so nothing scrapes?
Just a wood 4x4 under each of the rear LCAs.
ek2.0 has that same diffuser on his ek right? it looks so sick in person
great build thread!
Well i wasnt able to get my hands on a engine crane until today, big thanks to Mike and Matt B. for getting me one!
I took off the bumper so i could start trimming it for my intercooler core if i got bored
and i found this, PnP anyone?
took a brake to shave my pussy
i needed to remove the axles. Yay for princess auto quality
time for an upgrade
I had a hell of a time getting the pin for the shifter to come out and not having the right tools for the job dont make things any easier, but i modified a random bolt to do the job
and with the magic of the internet
Engine bay is going to get a good scrub down. ill be starting my wire/brake like tuck soon!
LOL fucking troll Andy, im not into lifted trucks so i need to compensate some how right?Originally posted by monkee_pride
Small Update:
My CTR door molding came in
More JDM goodies
Picked up some wire tuck supplies. Got some fancy wire loom... its a shame no one will get to see it really
Carbon broooooooo... not really tho
started the wire tuck tonight, didnt get very far....
the original plan was to relocate the fuse box to the glove back but after some test fitments the modifications required to make it work seem unnecessary. so after a little playing around i chose here
since my car is base model and does not have air bags ill be placing it here, fit much nicer. ill rig something up so i can just pop the dash panel off for easy access.
got the main harness out
bay practically free of wires
tomorrow i will try and get the fuse box mounted and wires soldered in place so i can move onto the headlights next.
Didnt get as far as i want to this weekend, too much other stuff going on but i managed to get the dash out and passenger side completely wire tucked. ill start on the driver side when i get around to it but probably not till after Christmas. building cars near Christmas hurts the wallet and when you brother's Bday (Dec12) and mother's bday (Dec25) are in the same month things can get out of control quickly. so for my brother's bday i polished his car. turned out pretty good, its a 3 stage polish. also the whole front end is 3M including half the hood, before i started the 3M was starting to fade but now u can hardly tell its even there.
What a nice brother!!!
I'm loving the progress! A TON OF WORK.
You needing anything sand blasted?
Not sure if I do but I'll give u a shout if i do thanks!
You know if you crack open the fuse box from the bottom..there are 3 plugs which separate the fuse box from the harness... No need to cut the harness and I moved mine in my glove box just had to push the harness back in though the firewall and plug the fuse box in..
The wires need to be extended that's why they were cut
its still a limp dick exhaust, no matter what you do to the car lol but seriously, its coming along nicely dude.
