I want to a put a posi into a cutlass,
the posi is out of a s10 so the cutlass axels splines are not big enough.
So im look for ether a place where I can get some axels or posi axel gears
The best quality Axel actually came out in 1984, there were a couple revisions released in 87 (arguably equal or better) and 94 (not really recommended for obvious reasons). I'd start your search there.
Originally posted by SJW
Originally posted by snowcat
Don't let the e-thugs and faggots get to you when they quote your posts and write stupid shit.^^ Fact CheckedOriginally posted by JRSC00LUDE
I would find out first if the Posi carrier will even work with the cutlass diff. There was a few different options.
Love my Viper.
Radio controlled rock crawling. www.rc-ab.com
It fits I already have it in and everything
I was about to put the axels in and they didnt fit
I guess they are 26 splines and my axel gears are 28
so I ether need to find 26 spline posi axle gears or 28 spline axle
That are the proper length
I already to the pnp and ripped apart all there ten bolt diffs and I cant
find the exact axles I need.
Axle...
Axel
Thanks, real helpful. Lololol
So I need 28.5 in, 28 Spline axles
Does anybody know a place in Calgary that does axles?
I hate to burst your bubble but that is actually Axl....Originally posted by ianmcc
Axle... Axel
Dammit-can't even mock properly!
THIS is an Axel, as referenced in my initial post.Originally posted by ianmcc
There are two types of G-body GM rear ends-7½" and 7 5/8". I think you have the 7 5/8".
The 26 spline are from the smaller rear end-you need axles from an 87+ era G-body or an S-10/Astro Safari van.
You can check 8.5" rear ends as well but I can't confirm they will fit your application.
