I have a 94 EG coupe si, the brakes have been pulsing for a long time, its not so bad with light pedal pressure, but with heavy pressure, or higher speeds (>90) its quite pronounced. first thought was to replace the front rotors, which did nothing, then I replaced the rear drums and shoes, nothing, and when I did the shoes and adjusted them now I have a clicking that has the same rhythm as the pulsing coming from the right rear drum brake, I though maybe the wheel bearing was fucked so I replaced it and still nothing, only thing I can think of is maybe the spindle that holds the bearing/hub assembly is bent, but apparently you cant buy that separate, you have to buy the whole trailing arm assembly.
I'm at a loss, its irritating and already have 200 in parts thrown at this problem, not to mention labor, so although I've considered just doing a disc swap and forgetting about it, Id rather not dump any more money into the problem.
any thoughts would be awesome!!
