Results 1 to 9 of 9
Thread: laminate at doorway
    calgary ab
    4x4
    Default laminate at doorway
    Quicky question,
    Ripped up some carpet on the weekend, replaced with laminate...
    Laminate at interior doorways... how do you trim around the door frame? I kept the 1/4" away per the directions... but it looks bad, as now there's a gap...
    If I cut it tight, the laminate no longer floats... and you cant exactly use 1/4 round in a door jamb to hide...
    What do I do here?
    '08 Audi A6 4.2L S-line
    Caulking?
    Dec 2006
    SRT Charger
    Cut the door frame/trim to allow the laminate to run under it, if you cut it too high you can use silicone to fill the gap.
    missy
    Use a door jamb saw to undercut your frames, run the laminate under the frames...
    CNC Guru*
    Instagram: goreski_rdd
    Great advice, I always wondered this but never tackled a laminate floor project... yet.
    Mar 2009
    Edmonton
    will use this advice next month... thanks!
    calgary ab
    4x4
    So addendum to the question, undercut and slide in works if its a starter course... but whaddya do on the back end? I cant tip up to interlock it... starting to think trimming laminates flush to wall then using 2 transition strips and a separate piece in the doorway itself...
    Apr 2010
    the pieces wont have to underlap the door frame casing much, so one side can slide under more, drop down, then slide back to even out
    pre-measure your laminate installed height, and cut the jamb/casing 'slightly' less, so then the laminate will push up under for a snug fit
    sand and paint touchup the jamb/casing cuts before hand
    use a paintable caulking, white if your jambs/casing are already
    laminate is just a picture of wood bonded on top of mdf, so it doesnt expand/contract like hardwood, meaning you can put it right up close to the wall, and that way ensure you dont have any gaps show from under your new base board
    you dont have to "hammer" laminate together, so many i see or redo are cupped or have damaged interlocks for that reason
    check the interlocks ahead of time, clean them out, and cut/sand and broken parts so the chunks dont get caught inbetween and cause a problem at install
    i personally check at purchase time, you'll discover many boxed have been hit, and the frail mdf interlock edges show breakage
    lastly, even click together, use some glue, just a drop here/there on both the length, and defintely on the ends, that will ensure they dont seperate over time, which i commonly see too
    good luck
    "Drive your business, let not your business drive you" ~ Benjamin Franklin
    Apr 2010
    do you mean where two pieces butt together like in pic above^^ ?
    what i do, is sand the interlock down a bit, so it doesnt need to tip up, and glue the two together
    the interlock still is there, just sand down the ridge inside till the two slide togther on the same plane
  1. Where to find "shatterproof laminate?"
    By t-im in forum General
    Latest Threads: 04-01-2006, 06:42 PM
  2. best place in CGY to laminate cards?
    By cityhunter2501 in forum General
    Latest Threads: 04-06-2005, 12:00 AM
  3. Laminate Counter top Installation
    By Gspotracer in forum General
    Latest Threads: 01-26-2005, 02:00 PM
  4. Laminate flooring?
    By Neil4Speed in forum General
    Latest Threads: 11-15-2004, 11:37 AM
  5. Fitting a car through a doorway
    By jbones in forum Mechanical
    Latest Threads: 07-06-2004, 05:17 PM
