I bought my Regal GS last year and all was well with the brake system no abs light on however they had very little life left in the pads, about 7 months after the abs light came on and there was a small tiny squeal/whine I had the Brakes checked out and sure enough they had to be replaced, as well as the driver side caliper as it was in rough way soo.... needless to say I did both front and rear Pads, Calipers & Rotors and bam picked up the car from the shop and all was well Abs light off and the brakes felt great... however about 2.5 - 3 months later the abs light came on and the squeal was back also I should note both times the squeal has been from the drivers rear, took it back to the shop and the rear pad and rotors were worn down mainly on the driver side so replaced both AGAIN ... now its doing it yet again ! So I am dead sure its not the caliper rotor or pads ... I sure there is a Bigger issue as it sounds as if something on the drivers side sticks or is warped I was wondering if any of you would have an idea of what it could be as clearly my current shop can't pin point the main issue I was thinking wire harness, sensor or maybe wheel bearing ?
any help / recomendation of a good brake shop that could get the problem fixed the first time not the 5th would be great as I've spent nearly $750 on this issue in 6 months and the car runs too well for me to want to get rid of it over this !
Thanks
-J
