Always fill with Shell 91
"Best" is subjective. If you have a boosted application making big power, you probably care more about high octane than good MPG, so you could consider one of the ethanol 94's as being "best".This quote is hidden because you are ignoring this member. Show Quote
If Co-op guarantees no ethanol, then the only difference between them and Shell, is that Shell will have their fancy nitrogen enriched secret formula added. But Co-op will just be your basic government standards 91 octane fuel. If you want to save a few bucks, then nothing wrong with Co-op. MPG should be pretty similar as it has no ethanol.
I'd be pretty leery about the supposed claim of "No Ethanol" from Co-op. 87 octane fuel is mandated to have ethanol in it. Refineries don't even blend an 87 octane fuel, they only blend enough heavy into the gasoline to achieve 82 octane, then get it to 87 by blending in ethanol once it's at storage.
They would be required by law to put a "may contain ethanol" sticker on the pumps if there was any ethanol being blended into the fuel. I don't think they'd want to open themselves up to a massive lawsuit and minor fines, just for the sake of a very little known thing such as this, especially when they don't even advertise it.
Doesn't change the fact that I'm leery about a company bypassing a federal regulation.This quote is hidden because you are ignoring this member. Show Quote
Understandable. My comfort that they dont, comes from the reason they started was because of the massive lawsuit that happened last time they fucked up their fuel.This quote is hidden because you are ignoring this member. Show Quote
That, and I always see a noted difference in fuel economy using their 87 octane vs others which have ethanol.
My 4Runner gets 87 from Shell, has since I got it like 7-8 years ago. I think the only way to truly know if Coop 87 gas is ethanol-free would be to test it, but I don't care that muchThis quote is hidden because you are ignoring this member. Show Quote
Source was from here: https://www.pure-gas.org/index.jsp?stateprov=AB
10-12% fuel usage savings using Co-op regular gasoline for the fleet of Chevy van/trucks at the last place I worked for. (compared to any other brand fuel in Calgary). I’d place money on not having ethanol in it.
Has anybody argued that Co-op does have ethanol in their fuel?
Sounds like Coop premium is ethanol free but regular and midgrade may not be http://crs.coopconnection.ca/files/P...s-GASOLINE.pdf
Federal regulations regarding ethanol content are for producers/importers only so it is very possible that Coop's retail offerings are all ethanol free.
Will fuck off, again.
I always missed Chevron gas from when we lived in BC, but it looks like they are putting one in on the old Fasgas property on 12th St just off Mcknight near my shop! Woot!
Only time I have ever seen a need for Shell in one of my bikes is on the turbo zx14. Every other bike has ran fine on basically anything. my BBC gets shell as well with a booster.
I think as all motors these days have knock sensors to adjust timing, you just don't find a huge difference between different gas at the same octane
that said, with a 2 stroke high compression (150+ lbs) motor, or a high performance high compression low displacement (say 600 or liter bike super sport) boy... yes, ethanol free runs cooler and more consistent.
^This.This quote is hidden because you are ignoring this member. Show Quote
I would say anything OEM is not going to break because you pumped 87 in a 91 recommended engine. The KS will take care of it and worst case, you have poor performance which I would bet you wouldn't even notice except on a hot day, jamming on it up a hill off a red light. At best, you'll have some lag which is timing being pulled and if this wasn't a car site, you'd just complain your C300 is getting old.
During your "World Rush Hour Championship" you won't even notice.
Shell's V-Power formula has been updated as of April. Apparently it has improvements to better protect against gunk, corrosion, wear and friction. Probably next to impossible to notice these improvements as part of daily driving, but i'm sure long term it has to be better for engines.
How do you figure gas runs cooler than ethanol?This quote is hidden because you are ignoring this member. Show Quote
not that its nature does, but I do believe that its been an outcome in the case where it may run leaner. Also Ethanol absorbs moisture, which is why most boats should avoid if it sits in a slipThis quote is hidden because you are ignoring this member. Show Quote
Though considering most people don't keep the same vehicle for much more than 7-8 years, its rather pointless.This quote is hidden because you are ignoring this member. Show Quote
Not sure what you're getting at but ethanol runs a lot cooler than gas because it has a higher latent heat of evap. Some guys running E85 or E98 on boosted applications can even get away without an IC whereas you'd definitely need one for a gas car. The difference between E0 and E10 won't be very extreme but you may see a nominal cooling benefit with E10.This quote is hidden because you are ignoring this member. Show Quote
Anyone done the math to see if the added cost of premium gas actually pays for itself by better mileage compared to regular gas?
My Karma ran over your Dogma
