Deck question - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: Deck question
    Sep 2007
    A vehicle or two
    Default Deck question
    Hey guys,
    I am just starting to build a 2nd, lower tier to my deck. The issue is that once you factor in the steps down to the 2nd tier and then factor in the space required for the joists and decking, there is not enough space for a joist-on-beam design for the area that is closest to the deck. Excuse what is quite possibly my worst ever photoshop job, btw.
    I'm really not too keen on adjusting the grade at all - so am I right in assuming I'd be best off with a flush beam design? And if so, what is the best way for me to implement this?
    This is not a large deck area (About 9.5X9.5), so that should help make the design easier.
    I would think that my best best would be double up the 2X8's for the edges both closest to the house and away from the house, then the joists can be single 2X8's attached using joist hangers. (The 2 joists on the outside perimeter would have to be screwed in without hangers) Then I would just rest the doubled up 2X8's on top of 4 4X4 posts which would be set in about 2 feet on either side to help distribute the weight.
    Is this an adequate design?
    Also, you'll see in my rough sketch there that the lower tier extends a bit longer than the stairs leading to the existing deck. Is that really retarded, or should I ensure the very edge of the addition lines up exactly with the bottom of the stringer?
    Dec 2011
    Depending on how high off the ground it's going to be, build it exactly like the deck you have just lower.
    Your deck will sag if there isn't support from a beam.
    Are you using concrete pilings?
    Sep 2007
    A vehicle or two
    I can't build it like the other one. There is not enough clearance, as there is only about a foot of vertical space in the area closest to the existing deck and the house, and less than 2 feet in the other corners of the proposed deck.
    For the footings I plan on doing what was done with the existing deck - which is simply setting posts in concrete-filled holes.
    Dec 2008
    Why not drop it down to a nice brick patio?
    Red Deer, AB
    I don't see anything wrong with the design, you have more than sufficient supports with the four posts underneath the 2x8 beams for the size of it.
    Looks good to me. By the way, when you mentioned a bad sketch I was expecting poorly drawn red & yellow lines from paint... that's a pretty solid sketch, I must say... lol.
    +1...
    A Brick Patio would look good there IMO...
    Less grass to cut as well.
    +1 on bric patio, although to do a good job, it is quite a bit fo work. IMO, doing decent brickwork is harder than the carpentry for a deck.
    Sep 2007
    A vehicle or two
    We thought about a patio, but decided against it since the grade is really steeper than we'd like and we also like the look of a double-tier deck.
    As far as the bad sketch goes - I'm a designer by trade, so one would expect my photoshop work to be a little more impressive. Plus, this was my 2nd crack at it... the first was... well... insufficient.
    '14 Audi S5 /'09 Forester XT
    Any particular reason why you want 3 steps down to your lower deck? Could you not build the lower deck so that the top of the lower deck is flush with the bottom of the upper deck or just slightly higher if the step is too big? That way you could build it the way you want to and still get the visual look of a upper and lower portion. The TV show Deck Wars does this all the time. I really like the look of the 2 tier deck but in your case you really don't have the vertical height to pull it off.
    Sep 2007
    A vehicle or two
    Good question. If we raised it up more, there would be room for the standard beam system. However, there are two reasons we're going down 3 steps to the addition.
    First, that puts the level of the addition just below the concrete well of the walk-up basement. At the same time, it puts the railing already on the walkup just slightly higher (About 2-3 inches) than where it would need to be anyway. So if we were to raise the addition, we would need to put another railing on that side because the one for the walkup well would now be too short.
    Second, we need the ability to walk off the addition into the yard anyway. So either we put 3 steps down then 3 steps off, or 1 step down and 5 steps off. Regardless, the same amount of stairs apply, and regardless of how we distribute them, they take up roughly the same space on the addition.
    Another thing I didn't mention is that I'm considering making the steps not only at the end of the addition, but along the front of it as well. While it will take up an additional couple of feet into our (already small) yard, it would be a nice effect and make the addition a little easier to use.
    300C srt8, Venza, F150, Expedition
    You have the right idea
    'flush beam' : this is what I get out of that;
    Double 2x10's over your posts at the level of the proposed deck, use joist hangers for your joists, place deck planks, railing if desired = end deck wars
    Burn some serious rubber on your Wedding Night!!
    Renovating a home the hard way:
    http://propertysensei.wordpress.com/
    If you don't want your posts too close to the edge, move the posts and run the joists the other direction.
    Sep 2007
    A vehicle or two
    Nah, the joists have to run this direction because the deck boards will then run the opposite direction... which is the same way the main deck already is. I want to remain consistent.
    Nov 2005
    Hondas
    You'd be surprised how good it looks to have the deck boards run perpendicular on the lower tier.
    Nov 2011
    I would put the steps towards to back yard and not on the side as in the drawing. As privacy looks to be a premium, build a nice wood fence or some high bushy type trees could go where you currently have the steps in your drawing. This way you are somewhat shielded from the one house next door and also from wind. Perhaps another limited "green/wood wall" on the side facing the backyard to give a little cove for a hot tub or nice intimate feeling space. Make it like your own little private zone.
    I assume you are using screws or a clip method (better and allows for the floor boards to be closer together) for securing the deck floor.
    As said above, good idea and it really does break up the design in a good way: "You'd be surprised how good it looks to have the deck boards run perpendicular on the lower tier."
    I too like a nice stone patio over and above all else. Post the after pics so we can see what you did in the end.
    Sep 2007
    A vehicle or two
    Interesting ideas, Canmoreorless. I never really thought about blocking the area off where the stairs are shown in the sketch with trees, or something high like that. Would look pretty effective, and will help with privacy.
    We're already moving on getting a fence built as well - though anyone on their own decks will still be able to see.
    That's something I'll chat over with the wife.
    As far as screws go... yes, I will be solely using screws. No nails.
    Nov 2011
    There used to be a landscaping guy on Beyond, he offered to secure some bushes and trees for me at a very nice price compared to retail. Green stuff is a pretty penny. If you do it right, your neighbours really cannot see much of your little private area. Just need to know the window angles, it will all add value to your house for sure. My sister in law lived in a like community, they did the rear area up right and it sold in a week. Gem of the block for sure. My buddy built a modest deck and included a square wooden tub in the floor for his kids to play in on hot days. One can get rather creative for little cash and some planning.
    Sep 2007
    A vehicle or two
    Well I thought about what you were saying, and realized there is a lot more people behind me who comprimise our privacy as opposed to beside us. In addition, we plan on renting a room in our basement and the tenant may want access to the deck too, so might as well keep the stairs closer to the walkup.
    I did throw this together though... assuming white rock as the base:
    '15 Grand Cherokee Summit, '18 Golf R
    I wouldn't do that with the trees - it'll create too much of a division between your deck and the rest of your yard. If you're going to put a long wall of trees like that, it should only be at your property line.
    A better option IMO would be to keep the 3-4 columnar trees on the right side by your existing deck, and have steps come down the front of the new addition. In the bottom left corner, put a single tree that'll grow up to provide a canopy and provide some spring/fall colour (crabapple, lilac, mountain ash, etc).
    Don't use white rock. Looks like crap after a few years and is a pain to get rid of. Just leave it as soil.
    Apr 2010
    you could move the trees toward the back edge of your yard instead of so close up, making the lawn space usable IMO
    i agree that the lower tier deck would look and function better with the steps down along the long side, in fact i'd say go further and make the step treads a bit more than usual for safety too, then put a matching railing along the side, or possibly a lattice screen to help improve privacy from the side neighbor
    to me the ability to have traffic flow through access from the house, the 2 decks and on to the lawn makes more sense
    ps. my white rock turned to crap in short time, i got rid of it and replaced with cedar bark, the bed had fir shrubs
    "Drive your business, let not your business drive you" ~ Benjamin Franklin
  1. Tax Question-Finance Question-Mortgage Question-All In One
    By 2BLUE in forum Real Estate / Finance
    Latest Threads: 10-19-2012, 05:37 PM
  2. WTB :::***Panasonic Car Deck***::: :::***Panasonic Car Deck***:::
    By SamerSam2003 in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 09-07-2004, 01:12 AM
  3. Kenwood Deck Flip Blackout Deck
    By fijianplaya in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 07-09-2004, 09:29 PM
  4. open deck/closed deck
    By GTS Jeff in forum Mechanical
    Latest Threads: 01-07-2004, 12:42 PM
  5. Trade a Deck for a Deck
    By Fosgate R in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 11-12-2003, 05:36 PM
