This quote is hidden because you are ignoring this member. Show QuoteI like having them, but their quality is shit. I've replaced the main bathroom one 3 times in the past 5 years.
So there are low spots in my single attached garage that cause water to puddle up after the snow melts off the car. Is it an easy DIY fix come summer time or do I need to hire professionals to re-cement / re-grade the floor.
Here's a bit of info I came across a while ago:
https://www.kompareit.com/homeandgar...e-raising.html
I've found that it's usually the temperature and humidity change that affects newly-installed door handles on wooden doors.This quote is hidden because you are ignoring this member. Show Quote
I replaced every single handset in my house and garage when I bought it (got rid of worn-out brass junk) and my interior wooden door handles required snugging up after a year or so, but the hardware installed on the metal doors (front and rear of the house, man-door in the garage, and fire door on my utility room in the basement) were still tight.
It really depends on why its pooling. Is this a new pad the was placed poorly causing a bird bath? If so you can add material but it can look a little off.This quote is hidden because you are ignoring this member. Show Quote
If the slab has sunk or heaved creating a pool that can be fixed with slab jacking. I'd go with Poly for a number of reasons. Most companies are around $750 minimum and depending on how far its dropped it can go up quickly.
Yeah the Leviton timers have a terrible rep for noisy relays. I went with the Woods timers instead, not quite as good-looking as the Levitons but at least they're dead silent.This quote is hidden because you are ignoring this member. Show Quote
Drill a hole in the lowest spot so it drains.This quote is hidden because you are ignoring this member. Show Quote
I like neat cars.
How big of a hole?This quote is hidden because you are ignoring this member. Show Quote
I drilled about x5 3/8" holes ~2-3" apart.This quote is hidden because you are ignoring this member. Show Quote
I like neat cars.
Setup the threader, converting my gas service to 2 psi with drop down regulators so I can down size the pipe run out to my new garage, running 3/4" at 2psig instead of 1 1/2" at 7"wc. Pretty big run, about 175 feet in total, ran 60' of black through the house.
Too loud for Aspen
How about the decora remote wifi switches, ever try them? I F'd around with it for about 2 hours the other night, it will not communicate, doesn't reset like the instructions say, the app can't find it... Its like their instructions are written for a totally different product...This quote is hidden because you are ignoring this member. Show Quote
Too loud for Aspen
Well woke up to water dripping through one of my my ceiling lights in the living room. Almost a drop every two seconds. Turns out one of the vents on the roof is completely frozen over and snow melting in. There's like 20 inches of snow on the roof so spent the last 90 mins shoveling snow off the roof. Still need to somehow break the ice.
Trying to play nice guy today, filling up these dips.
Updated: March 10, 2022
My list of random For Sale (some free) stuff
North side of my roof is pulling down the troughs. Will be going out with garden hose and hot water this weekendThis quote is hidden because you are ignoring this member. Show Quote
Really with this warm weather, you're just hiding the ruts, lol.This quote is hidden because you are ignoring this member. Show Quote
Think I made it worse. More slushy nowThis quote is hidden because you are ignoring this member. Show Quote
Had to pull some plumber out of the snow kitty corner to my place. Nearly got him out just pushing. Decides to save my back and use a tow strap.
Has anyone here ran a water line from their basement to the garage? Looked online and couldn't find anything.
Looks like I can run the line from the water header in the basement, through basement joists into the garage.
For what purpose? are you putting a sink in there.
