what did you do around the house today? - Page 41 - Beyond.ca - Car Forums
Page 41 of 157 FirstFirst ... 31 40 41 42 51 ... LastLast
Results 801 to 820 of 3130
Thread: what did you do around the house today?
  1. #801
    '14 Taco
    Got the bikes up and deck stairs on
  2. #802
    Nov 2005
    A Slow Car
    My Cousin and I installed a bio flame fireplace in the basement
    “Straight roads are for fast cars, turns are for fast drivers.”
  3. #803
    Mar 2011
    Its sort of shocking how similar your theatre room looks to mine!
  4. #804
    Nov 2005
    A Slow Car
    Quote Originally Posted by lasimmon View Post
  5. #805
    Mar 2005
    Foothills County
    is faster than yours
    Finally got around to staining and varnishing a bunch of trim and baseboard for the basement and master.
  6. #806
    N/A
    Dump run, had to pull wet stuff out of the house because of the June 28 storm that saw our yard get 10cm of rain in about 2.5 hours. The rain water was flowing into our yard from the alley as well and we ended up with the water being 4-5 inches deep against the side of the house and a couple of basement windows. 311 report into the city already to have them regrade the alley so as to have storm water drain down the alley instead of into our yard. Multiple homes on our block had seepage/flooding as well although worse than ours, neighbor directly south of us had to pull up their laminate floors in their basement, the water was coming in faster than they could suck it up with a couple of wet/dry vacs.
    Will fuck off, again.
  7. #807
    May 2004
    Ford, Acura
    One of the piles for my deck/patio sunk over the winter with the frost heave (but the other 5 didn't????) and dropped one corner of my deck just under 2 inches. I took the car jack to the underside and replaced the post with one that was 1-7/8" longer and leveled that bitch out. It was wayyyyy easier than I thought it would be, but don't tell my wife that because I've been putting it off for a couple of months.
    I'm generally cute.
  8. #808
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Re-doing all my fencing. Some nasty stumps from those fucker tree's that grow under ground an sprout everywhere. one was right where a post needs to go, got that fucker out.. after about 1.5hrs of struggling. dug it up, hacked the roots with the axe, put lag bolts in and pulled it out with my motor hoist haha... one more to go.
    Also doing a deck, do i have to do concrete piles if it's a floating deck? someone was telling me i could just use those deck support blocks? its about 16'x20' 2x8 joists and 2x8 beams composite decking.. Can i just put patio blocks down with those deck blocks on them? I hate concrete piles....
  9. #809
    '14 Taco
    Quote Originally Posted by JfuckinC View Post
    Depends on height of the deck, which will dictate permit requirements. If it's under 2 feet, and not attached to the house, i'd do deck support blocks. I only did piles because i was using the ledger on the house, as well as didnt trust the compaction for deck blocks with the bozo house builders
  10. #810
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Redoing the bottom cabinets... replacing old doors with drawers. Kitchen was ikea originally, thought “hey! This should be pretty straightforward... just buy the bits for this width of cabinet!”
    NOPE! IKEA changed EVERYTHING from this gen of kitchen till current. “30” tall” use to mean a hair over 30”, now its a hair under. “13” corner cabinet” doors are now over 13”, while they use to be 12”... that was fun. Love when an ikea build also includes a table saw, hole saw, and chisel
    Also have to redo the P-trap and it’s about 1/2” too low for the shallow 17 3/4” drawer under the sink... plumbing also runs through the two bays beside the sink so thought “no problem! Just swap these 24” deep drawers for the 17 3/4” ones!” Nope! They don’t come narrower than 24”... so building a hybrid of a 24” x 17 3/4” and 15” x 24”... rails and track from the 24”, bottom and back from the 15” with a run though the table saw to make it 17 3/4” deep
    And to top it all off... the cabinet hole patterns and not even remotely similar, so I will be drilling new mounting holes for all of the tracks. Current style is a double row out front, then two single rows at middle and back... old style is two single rows, and even the spacing between rows is different
  11. #811
    Sep 2008
    NE
    It's under 2' for sure. Fuck me i love that lol, sick of the auger and mixing concrete.
  12. #812
    Bunch of Honda's
    I would never build a deck on those deck blocks personally. They move around so much I wouldn't trust them to not heave and sink till the end of time.
  13. #813
    Sep 2008
    NE
    I'll probably use 9, on patio blocks on tamped gravel........ Maybe i'll regret it.. lol
  14. #814
    Sep 2012
    I used deck blocks for a very low deck, turned out fine. Stayed stable for years. I waited three years though before building it.
  15. #815
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by ercchry View Post
    Much better...
  16. #816
    Aug 2015
    SL550, P100DL, F-450, FIAT
    Hopefully you’re changing the top too?
    Professionally Retired
  17. #817
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by KPHMPH View Post
    The top is a whole other bunch of issues... ikea has changed the depth of their boxes so the current corner cabinets use a 15” door (so 14” and change width) while this one is around 16 1/2”, so would have to cut down an 18” door... they also don’t make 24” tall doors anymore... I have 4 24” tall doors. I’m thinking I will put a built in microwave in the new full height cabinet, and delete one of the 24” tall bays by doing a full height range hood. Which of course means extending the backsplash to the ceiling too... then the bay above the fridge either cut down 30” tall doors, leaving the cut edge at the ceiling, or do floating shelves... the 30” doors they do sell are too tall and would hit the fridge.
    But since that does nothing for the functionality of the kitchen, and since two tone kitchens are a “thing” right now so it doesn’t bother the GF... that’s not high on my priority list at the moment
    I will be updating all the pulls though to help tie everything together
  18. #818
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Put on the new bug / stone deflector on the truck.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
  19. #819
    Jul 2008
    Edmonton, Alberta
    Finally got around to putting up Cameras. Did one for the backyard this afternoon. ended up using an existing pathway into my house where I used a PoE injector and a Powerline network kit to get it to my server downstairs.
  20. #820
    2008 Z06
    - Installed 1km of wire for an electric dog fence. 9 acres total. Training is going well. Assholes can't run away now. https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
    - Dump run, felt good to get rid of crap.
    - RoundUp weed sprayed everything.
    - Treated the water softener with IronOut to clean the resin.
    - Had the septic tank pumped. Added treatment to the septic tank, more bio.
  1. What did you do to your car today?
    By 6Speeder in forum General Car/Bike Talk
    Latest Threads: 01-09-2018, 09:39 PM
  2. What did you do to your FoST/FiST/Fusion today?
    By RedApe in forum Ford ST Owners Club
    Latest Threads: 06-21-2015, 09:33 PM
  3. What Electronics did you buy 10 years ago ? and which do you still use today?
    By thetransporter in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-01-2012, 07:45 PM
  4. Did you have turkey today?
    By Awd-Tsi in forum General
    Latest Threads: 10-11-2010, 04:49 PM
  5. Replies: 27
    Latest Threads: 11-13-2004, 05:25 PM
