Help with 5X5 routine - Beyond.ca - Car Forums
Results 1 to 20 of 27
Thread: Help with 5X5 routine
    Airdrie
    '16 Sportwagen
    Default Help with 5X5 routine
    Hey Beyond. I have started a 5X5 routine recently and have been really enjoying it but I have some questions about how I should be applying the weight to each individual set. I have looked over a few routines from different sources and there are 2 main differences between them.
    Style 1: Use the same amount of weight for all 5 sets. Increase the amount of weight when able to do 5 reps on the 5th set.
    Style 2: Ramp the weight up for each set. For example: set 1=100lbs, set 2=125lbs, set 3=150lbs and so on until your 5th set is your 5 rep max essentially.
    I have no idea which one is right or maybe they are both right. What is your take on it? What would you do if it was your routine?
    Calgary, Canada
    958.2 Cayenne Diesel
    I started with Style 1, and then did Style 2. I don't really notice too much of a difference, nor did I switch the styles for any good reason.
    Originally posted by arian_ma
    your stomach is full of sulfuric acid
    rally pig
    5x5 should be all done with the same weight and technically you are doing more than 5 sets as you will be starting with no weights first, then gradually increasing your weights.
    ie what I do for squats
    SET1 = 45lbs
    SET2 = 45lbs
    SET3 = 135lbs
    SET4 = 135lbs
    SET5 = 225lbs
    SET6= 225lbs
    SET7 = 225lbs
    SET8 = 225lbs
    SET9 = 225lbs
    Airdrie
    '16 Sportwagen
    SET1 = 45lbs
    SET2 = 45lbs
    SET3 = 135lbs
    SET4 = 135lbs
    SET5 = 225lbs
    SET6= 225lbs
    SET7 = 225lbs
    SET8 = 225lbs
    SET9 = 225lbs
    I do warmups similar to what you have posted here. I just am not sure what to do for the 5 working sets. Currently I do style 1 myself.
    Nov 2004
    Default Re: Help with 5X5 routine
    When I do 5x5 I do style one. Two warm up sets of roughly 50% of my work set, then 5 work sets of 5 reps. Works great for me.
    the simple thing to do would be to pick a 5x5 program and follow it, instead of trying to create your own. You will make gains on all of them. If you know that you respond better to more volume, go with a 5x5 sets across program. If you respond well to less volume, try a ramp up 5x5 (Bill Starr) or a 3x5 program (Starting Strength)
    You won't know till you try.
    heloc that shit
    Jun 2010
    I do style two for bench. I like it best and have been doing it for about 2 months time and have gotten much stronger.
    Mar 2007
    My cousin taught me that 5x5 should be done with the same weight for all 5 sets. With that being said though, on your last set, you are not necessarily going to get all 5 reps in.
    You always want to do more work at the gym, so every single time you come back to that exercise, you need to do more.
    Work = Force (x) Distance
    So you're first time on a new weight, say you only get 3-4 reps on your 5th set. That is fine, but when you come back later on that week to the exercise (or next week depending) Try to get the full 5x5. Then when you come back again, up the weight. Force is the weight, distance is the reps you are taking. Increase either, and you will increase the work put in.
    If you are looking for more strength though, I would strongly suggest looking into a 5-3-1 plan.
    Chinatown
    NC1
    If you've never worked out before, 5X5 will be good, start with just the bar and keep adding weight until you can't anymore, usually peak out in 2-3 months. (Beginner program)
    531 is a lot slower, you are adding weight every month as opposed to every session on 5X5. (Intermediate program)
    Originally posted by rage2
    Shit, there's only 49 users here, I doubt we'll even break 100
    I am user #49
    Aug 2008
    TDi
    Damn I just started this program and just finished the second workout. It's depressing lifting a little more than a bar. Patience is going to be key during his program. I hope I have enough though :/
    GO FLAMES GO!
    Mar 2007
    Edmonton area
    Has wheels
    Yeah it is, but it will promote good form and it's also a good motivator when you're always adding weight every workout.
    Give it a honest effort, the strength gains you'll notice will keep you going!
    Nov 2004
    Check your ego at the door, it has no place in a gym.
    I started 5x5, and within 3 months was benching 165 comfortably, squatting 225 properly, etc.
    The weight will come as long as your form is correct.
    Aug 2008
    TDi
    Thanks for the advice lol. It's going to be tough but I am also making sure that I am keeping track of the progress. 5x5 has an application that you can download from the apple store and it works pretty well.
    I've never done overhead press before and the weight isn't hard but I having a small problem with balance. Maybe because it's a lighter weight? Also, deadlifts at small weights feels awkward
    GO FLAMES GO!
    Jul 2006
    Victoria Park
    As long as you keep at it, I don't see why anyone cannot excel. I've seen people who work out one week, then get lazy the next blah, go on vacation, excuse this and that.
    You get what you put in. That's all. Good luck man
    Edge
    ^ This.
    Big ego typically leads to too heavy of a weight too soon, poor form, greater chance of injury, over-training and lack of progress. Leave that to the people who laugh at others in the gym.
    Aug 2008
    TDi
    Yeah I had to control myself and make sure that I didn't "accidentally" change the weight from 65lbs bench press to something higher.
    How far are you guys into the program? Once it gets tough should I switch up the types of workouts?
    GO FLAMES GO!
    Calgary, AB.
    210000 km oldie
    Where do you workout 403? I can use a training partner.
    Aug 2008
    TDi
    I workout at anytime fitness, not because it's a good gym but because it's 2 minutes from my house
    You're probably stronger than me
    GO FLAMES GO!
    Airdrie
    '16 Sportwagen
    Well I'm two weeks into the program and so far I like it. I stuck with keeping the weight the same for all 5 sets. The hardest thing so far is the barbell row. It's hard to have enough weight to get a workout but to keep balance when I am bent over. I bet it looks quite funny when I do it lol.
    Feb 2009
    Slow And burns oil !!
    I do the 5x5 on the bench in 45lbs increments.
    5xbar+45lbs(one plate split even)
    5xbar+90lbs(one on each side)
    5xbar+135lbs
    5xbar+180lbs(2x45 on each side)
    5xbar+200lbs. Thats my max. Working up to bench more but it takes time.
    Booooooooosted Da9
    WD21 pathfinder mud rig
  1. Replies: 4
    Latest Threads: 12-18-2011, 03:52 PM
  2. Help w/routine, and forearm issue
    By ShelbyMopar in forum Body Building / Weight Training
    Latest Threads: 05-15-2009, 12:56 PM
  3. WTB: 5x5.5 Rims
    By spikerS in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 10-16-2008, 01:16 PM
  4. Help with supplements and workout routine plz
    By 3G in forum Health and Fitness
    Latest Threads: 05-31-2006, 10:35 PM
  5. workout routine (help)
    By pyro in forum Health and Fitness
    Latest Threads: 05-31-2006, 05:36 AM
