Sunday August 12th
Classes and Sponsors
Real Street (2 Or less Performance adders) JB’s Power Center
Quick Street (3 Performance adders)Farleys Truck and Auto Addictions
Super Street (4 Performance adders) –MKS Trailer Repair
Pro Street (5 or more Performance adders) Horsepower Solutions
Outlaw (6 or more Performance adders) -Pro Stock Performance
11.50 Index - (Anything goes, run faster then 11.50 during eliminations and your out) - MRL Performance
12.50 Index - (Anything goes, run faster then 12.50 during eliminations and your out) -JB’s Power Center
Sport Compact – Speedtech Racing Development
***Class Rules***
4 Cylinder = 0 Power adders
6 Cylinder = 1 power adder
8 Cylinder or larger engine +2
Turbo/Supercharger/Nitrous +1 each
AWD +1
Alcohol as main fuel source + 1
Sticky tires 10.5” or UNDER or 295 drag radials or UNDER + 1
Sticky tires over 10.5” or 295 and OVER if a drag radial +2(Includes 10.5W)
All cars will be checked for DB of noise at 3500 rpm no load - if over 95 db +1
All cars must have valid Plates and registration.
Absolutely NO Tow backs or Tow Vehicles
Any Bye runs must be within 15% of your previous best run
***New sport compact shootout***
1. Primary fuel for eligible vehicles must be gasoline. Use of Race Gasoline and E-85 permitted. Water/Methanol Injection is permitted. Nitrous Oxide is Permitted. Alcohol is prohibited
2.Eligible cars must be streetable with the exception of tires. All variations of tire construction are permitted. Bias ply Slicks, Drag Radials or Street Radials. Any size DOT radial tire is permitted. Maximum size slick or DOT bias ply tire is 28.0” x 10.5”
3. Eligible engines (v8less) must be of an overhead cam (OHC) configuration. [exception: RX-7/8 Etc. Rotary]
4. All formats of drive, be it RWD, FWD or AWD are eligible for the shootout.
5.Suspension: All cars must utilize stock front and rear suspension and mounts. Aftermarket front control arms, rear control arms, and sub-frame connectors are permitted. Aftermarket struts and shocks are
permitted. Ladder bars, four links, and wheelie bars are prohibited on all cars.
For the purpose of this class a Sport Compact is defined as follows:
Any vehicle with an OEM engine displacement less than 3.8L. [3,800cc or 231 cubic inches.] Cars with stroker kits are permitted, providing that they do not exceed the displacement cap. Example a stroked 370z would be ineligible. A 2.4L stroked to 2.6L would be eligible.
***Just Some of the Bonus Prizes***
Quickest 60 Foot
Quickest Et Naturally aspirated
Fastest MPH Naturally aspirated
Best Wheelstand
Quickest N2O pass
Quickest pass by a truck
Quickest ET Of the Event
Best R/T of event
Quickest pass by a sport compact
Quickest Drag Radial pass(295& under)
Quickest 60ft on a Drag Radial(295&under)
Quickest ET by any Modular ford powered entry
Quickest ET by any ford powered entry
Quickest pass with a manual transmission
Fastest Mopar
Come out support a full day of HEADS UP racing, with classes for everyone and plenty of bonus prizes almost everyone can leave with a pocket full of $$$.
