Would there be better water flow if I used 2 45's instead of a 90 on household pex line?
On a pressurized household water line?
No worries about flow; it will remain relatively the same.
On a gravity drain, yes: 2x 45's are better than 1x 90
*btw: you can't buy 45* Pex joints. No point for them as the Pex line can curve and turn, except in tight spaces where a 90* will be required.
That makes sense.
Thanks!
