My bench press - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 44
Thread: My bench press
    Chinatown
    NC1
    Default My bench press
    How does it look?
    I weigh 150lbs.
    Bench is by far my weakest lift but I still did 135. Dunno if I want to push more weight. It felt alright. Might need to go chill with a790/kryn/warcaster soon.
    Originally posted by rage2
    I am user #49
    Oct 2011
    Lotus Land
    G37X
    Considering your weight, I think that is pretty impressive.
    I wouldn't personally lock out all the way when your bringing the weight up. It's harder on the shoulders and you will give your chest/triceps better stimulation if you pause and bring it back down just a little earlier.
    May 2004
    114°W 50°N
    Good work!
    Try doing 4 reps that have a rhythm of a slow count of 1, 2, 3 on the way down and 1 on the way up and like was said try no to lock your arms at the top.
    Aug 2008
    TDi
    Nice job, it seems like your left arm is lagging a bit behind your right; do you notice that or is it just me.
    Good you're not bouncing the bar off your chest. I see a lot of guys do that with the heavier weights and it makes lifting easier. Keep at it and you'll hit 225 in no time
    GO FLAMES GO!
    May 2007
    has a stick axle
    Default Re: My bench press
    How does it look?
    I weigh 150lbs.
    Max_Boost! Your form needs work (if you want to maximize your bench)! Come to Strive for a free lesson anytime. Like you my bench is not my best lift, but I understand the dynamics of it. I think you could put 20lbs on your max in a few hours just by working your setup and a few other minor things. Regardless keep on lifting!
    Jul 2006
    Victoria Park
    Do you find that the belt helps you a lot for bench or not really?
    Sep 2009
    I am 160lb my 1rm bench is 305.
    If you want to put weight on your BP try the Smolov Jr; http://www.seriouspowerlifting.com/2...cles/smolov-jr .
    This works for squats too
    May 2007
    has a stick axle
    Post a video of this bench press please, you should be competing if you can bench over 2x your body weight.
    Calgary, AB.
    210000 km oldie
    Thats pretty good Max. Did you see the video on the same youtube page? That chick arched her back like crazy. Anyways if you want spotter/training partner let me know. I have membership at Worlds. With consistency your lift will be fine.
    Sep 2009
    I do compete, I plan to set a record October 20th at the UAPA PowerSurge III meet in Edmonton. SQ is 425, DL 405.
    Also, to the above poster, arching your back is essential in a powerful lift. If you do it properly it isn't hard on your body.
    May 2007
    has a stick axle
    Raw or Equipped?
    Who are you? Did you recently go to Provincials? Are you training out of Calgary or Edmonton?
    I will see you there, I am heading to Power Surge with another beyond.ca member I train with.
    How does it look?
    I weigh 150lbs.
    Looks decent, form is def an issue as stated. Its hard to tell but your hand positioning looks more on the close grip side. Have your thumbs in line with the "line" stamped on the bar. You can tell you have the strength, but the form and brute style of lifting is killing you.
    Slow it down, dont lock out and breathe. Learning incorrect lifting / training techniques take alot longer to undo, than initially learn.
    The amount of weight on the bar is irrelevent if the form is off. More susceptible to injury also.
    Sep 2009
    Raw, no I wasn't at provincials as this will be my first competition. I only got into the sport about 3 weeks ago from my friend who is a powerlifter. He told me I had to compete because he was saying my lifts were already at a national level. Didn't have any clue until I did a little more research.
    Mar 2007
    How does it look?
    I weigh 150lbs.
    You have the same problem as I did. Left arm lagged, and I know you're pushing harder then on that. It's a really easy way to throw out a shoulder.
    Buddy of mine threw his out and couldn't work out for a very long time.
    What fixed mine was someone critiquing my form, but mainly closing in my grip. I find I get a much better workout in my chest with a closer grip too, and it fixed my left arm lagging.
    May 2007
    has a stick axle
    Awesome, good luck! I look forward to watching you compete. I assume you are out of Edmonton then as the community up there is a lot bigger!
    Chinatown
    NC1
    Thanks for all the comments. i always suspected my form was off but then I never took this stuff that seriously. Just kind of ho hum lift some weights and don't hurt yourself.
    This is pretty much my max lift haha at this weight everything feels fine but I am hesitant to push harder without first making sure the form was on.
    Thanks kryn maybe I will make it around to Strive someday haha
    I am user #49
    May 2007
    has a stick axle
    Default Re: Re: My bench press
    Uhh what? When you bring your grip in closer you are using less chest and more triceps...
    Mar 2007
    Default Re: Re: Re: My bench press
    Not super close, but just not as wide as I was doing before.
    I feel my chest burn way more after this.
    Jul 2005
    Default Re: Re: Re: Re: My bench press
    I think this is a sign of weak shoulder muscles. Can someone confirm?
    #1: don't ever question me.
    Feb 2008
    This article helped me a lot with my form when I was refining it.
    http://www.bodyrecomposition.com/tra...technique.html
  1. WTB: Bench press bench
    By DomesticBoy in forum Fitness & Sports Equipment
    Latest Threads: 12-17-2008, 04:27 PM
  2. WTB: Boost/AF/Oil press/Fuel Press/EGT
    By 1-Bar in forum Automotive Parts [Engine Electronics]
    Latest Threads: 09-18-2006, 10:41 PM
  3. NEED: Shop with press to press out bushings
    By bmeier in forum General Car/Bike Talk
    Latest Threads: 07-21-2006, 04:29 PM
  4. 900lb bench press
    By redablazin in forum Health and Fitness
    Latest Threads: 03-16-2004, 11:29 PM
  5. WTB bench press
    By B69 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-07-2003, 07:21 PM
