hp dc7700 hp processor thermal protection activated (2 beeps 5 times) - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: hp dc7700 hp processor thermal protection activated (2 beeps 5 times)
    acura TYPE A
    Default hp dc7700 hp processor thermal protection activated (2 beeps 5 times)
    so i have this bussiness PC i bought .
    i only used it a few times . i plugged in, beeps 2 times in 5 intervals.
    hp says the hp processor thermal protection activated
    how on earth would i reset it? the machine does not POST.
    i left it unplugged for a day, held down cmos reset for 30 seconds, left battery out , its in a really clean room so there is no dust inside and the fans work .
    Any suggestions?
    High River
    2004 Mini Cooper
    take the CPU out and re apply some thermal paste?
    Feb 2004
    werd
    re seat the processor
    take it off and clean with alcohol
    reapply thermal paste
    Check out the proper POST beep codes for HP mini-desktops here:
    http://h10025.www1.hp.com/ewfrf/wc/d...cname=bph07107
    acura TYPE A
    thanks REV. (thats where i found hte error code ) but it didnt give me too many suggestions.
    Ill take the fan off and apply some thermal paste.
    but the strange thing is detects the error without even fully turning on . i wonder why.
    Oct 2009
    Unknown
    1) Try powering it up with only the monitor connected.
    2) It probably has more than one stick of ram, so try one at a time.
    Oct 2009
    Unknown
    Any update on this?
    BTW- I seriously doubt the processor is overheating unless someone was messing around with it, or a heat sink clip is broken. This is especially true given that the system doesn't even post.
    In most cases, the beeping will be caused by a defective device such as ram or a video card, or a failed mobo.
    acura TYPE A
    HI Seth.
    The system does turn on for a few seconds and turns off. I disconnted the speaker when i last tried so i dont wake up the kids
    The machine has on board VGA. but i disconnected ALL hardare .
    even tried one stick of ram, in the first slot (black)
    I just got it from the ERA (about 130$ ) i really dont want make it an issue to exchange it.
    Oct 2009
    Unknown
    Looks like it's the cpu and/or mobo.
    Neither would be a cheap fix given how much you paid for it, and you could replace the processor or mobo only to find out that the other is also defective.
    acura TYPE A
    Ok ok. If its the MB , do you know if my MB would support the qx9650? I see they are the same socket set. I did internet searches with no avail.
    Thank you
  1. compustar command start horn beeps when ever battery dies
    By jason3935 in forum In Car Entertainment / Electronics
    Latest Threads: 12-13-2011, 10:34 PM
  2. LF: AMD LE-1250 Processor (or similar low power processor)
    By nobb in forum Computer Hardware & Peripherals
    Latest Threads: 01-02-2010, 06:39 PM
  3. Horn Beeps with Compustar Auto Start
    By B737 in forum In Car Entertainment / Electronics
    Latest Threads: 06-05-2009, 08:24 PM
  4. 3 beeps
    By eikna in forum BMW Marketplace
    Latest Threads: 07-10-2006, 11:05 PM
