^ They'll show you're serious and put your foot in the door more so then anybody that doesn't have it (That shows you have initiative and you're serious) but most companies will put you through their programs just the same. Its a waste of money & time on your behalf, but it does help. Thats what I did.
With Chemistry, that wont do too much for you asides from perhaps getting you on with a "frac" company/crew that uses fluids exclusively.
You may want to check out Schlumberger, or other similar companies.
Asides from that, you'll likely be doing something well out of your field.
