Computer soooo slow! - Beyond.ca - Car Forums
Results 1 to 20 of 39
Thread: Computer soooo slow!
    May 2007
    '19 GTI
    Default Computer soooo slow!
    Im pretty retarded when it comes to this, but my computer has been running ridiculously slow lately.
    It is a proper build from MemExpress, and i've never had a problem with it until now.
    For the past couple years i have been running eset NOD32, and Spybot S+D, and the Windows scans, all find nothing wrong.
    I see no issues with my computer in and of itself, however, internet browsing is ridiculously slow... and i know its not my local connection, since another computer in my place works 10x as fast browsing, and its a crappier unit.
    What could be wrong? Since all the scans show nothing?
    Ive also checked startup in system config. and nothing unnecessary is being run at startup.
    Pissing me off it is.
    Nov 2003
    Moo Town
    (0^oo^0)~
    have you checked your task manager to see what is sucking up all your computer resources?
    did you install any new software on your pc??
    Grimace
    Maybe good time to reformat
    Check your HD data speeds with a simple tool like Crystal Disk mark.
    If your drive is failing, it will tend to slow down over time as the heads/surfaces/etc. degrade.
    Your drive SMART status should also tell you a bit (although SMART isnt 100% reliable).
    I've got a similar problem.
    Downloaded CDM, and got the following score, is this good or bad?
    ^ run CDM with 500 MB and 3 passes, the sequential numbers are what I'm really after
    May 2007
    '19 GTI
    These numbers look like a stud in comparison to extraslow's, but still effin slow.
    ^ what are your hardware specs?
    Aug 2011
    Strathmore
    2005 Dirtymax
    Verify that your system hasn't become infected somehow and using a 3rd part proxy for your internet connection.
    http://support.microsoft.com/kb/135982
    Not sure if this is what you mean, but I ran it three times.
    1,2
    3
    May 2007
    '19 GTI
    Motherboard:
    ASUS M4a78lt-m LE
    Kingston 2GB 1333MHz DDR3 CL9
    Seagate 500gb 7200 HD
    Windows 7 Home
    (i think thats all the relevant info), let me know if im wrong
    hmm... I posted earlier but the reply was deleted,
    swak what is the browser you use?
    Those CMD numbers look fine to me - problem is not there obviously.
    extraslow - are you running an IDE drive?
    Uh, I'm running . . . . well this is embarrassing, I'm not sure.
    it's a Dell build from about five years ago. Would have been pretty high end at the time.
    I know it's not going to match anything newer, just wanted to see if it was malfunctioning. I have plans for an upgrade, but have been spending all my money n kid stuff lately.
    So, slightly on topic.
    Aside from any issues I may have with my desktop, something is making my NAS really slow.
    I'm running a Dlink DNS-323, and even browsing the folders stored on it is awful. It hangs up about half the time. If I do brows to the folder I want, transferring files can be really bad. Seems to be slightly intermittent.
    Not sure if this is a problem with the desktop I'm using to access the NAS from, the connection somehow (wired connection through my router, both ways), a problem with the hard disks in the NAS (WD 1.5TB Caviar Green), or some problem inside the NAS.
    what's a reasonable way to troubleshoot this?
    Feb 2007
    Aug 2003
    City:Calgary State:Omnipresent
    AE92GZE, Legacy BL, Yaris
    Default Re: Computer soooo slow!
    here's the first place to start ..
    download ccleaner http://www.piriform.com/CCLEANER
    run the cleaner.
    run the registry cleaner
    click and open the tools -> startup
    disable things like googleupdate.exe, divx update, adobe, quicktime etc etc.
    you'll see a few programs for things you know you hardly use disable them - if you do not know what it is for leave it enabled.
    (do leave java update enabled)
    reboot and see if that helps.
    Aug 2003
    oh and make sure you run all the windows updates
    Oct 2009
    Unknown
    If Task Manager shows the CPU and memory as normal, then the next step is to try the computer out in Safe Mode With Networking. If it's still slow in SMWN, then 99% of the time, the cause will be a failing hard drive.
    I've found that type of hard drive test to be much more accurate than drive testers.
    Oct 2009
    Unknown
    Default Re: Re: Computer soooo slow!
    run the cleaner.
    Neither of those have any impact on computer performance.
    In fact, the former will delete the IE cache, which is designed to make web pages load faster.
    The latter is full out snake oil, but even worse, can damage your operating system.
    Aug 2003
    Default Re: Re: Re: Computer soooo slow!
    Seth I know you know more than me but I can only say what has worked for me - and each of the processes has helped on more than a few computers that I have cleaned.
    1. from microsoft.com ....
    Remove temporary files
    Run once a week
    Your computer can pick up and store temporary files when you're looking at webpages and even when you're working on files in programs, such as Microsoft Word. Over time, these files slow your computer's performance. You can use the Windows Disk Cleanup tool to rid your computer of these unneeded files and to help your PC run faster.
    http://www.microsoft.com/athome/setu...id=PKASVo1jAwP
    For me cleaning temp files is a must in the first step of any computer related maintenance as it speeds up any following processes. CCleaner does the same job as recommended above by microsoft only it is both quicker and more thorough.
    2. He could avoid using the registry cleaner if he wants. However, ccleaner is the least intrusive registry cleaner out there and it does allow a backup. I use it and have only had positive results.
    3. CCleaner is also the safest and easiest way for the non savvy to enable or enable processes. Someone brought one computer for me too look at and it had over 30 extra processes and updaters running.
    4. The next step if the above three do not help is to check for disk errors ... of course ... as I mentioned above cleaning several gigs of temp files as recommended above will also speed up the process.
    http://windows.microsoft.com/en-GB/w...ive-for-errors
  1. i am soooo F**kin' sick of this Bullshit..
    By Illusionsir in forum General
    Latest Threads: 03-07-2003, 12:16 AM
  2. This would be soooo sweet to own!!
    By Rydog in forum Cars, Bikes, Machines
    Latest Threads: 02-28-2003, 07:55 AM
  3. Soooo Wrong
    By sexualbanana in forum General
    Latest Threads: 12-01-2002, 05:58 PM
  4. I'm soooo tempted to swipe the visa...
    Latest Threads: 11-12-2002, 04:14 AM
  5. new bmw silver, soooo good looking
    By TomTom in forum Street Encounters
    Latest Threads: 09-18-2002, 06:50 PM
