probably got it from https://www.cdnrg.com/ its down by PA, that's where i got my 4x 6v's
User title molested by Rage2.
How big is the TV?
Believe it or not the two single boxes will be better in the long run because you can actually pick them up and keep them in the box over winter storage. I had a double and it was much easier to store them when I switched to singles because it didn’t involve lifting 2 6v at once or taking out the batteries then the box then repeating.
E .· ` ' / ·. F
Your tears fuel me
I just lifted the entire box, it was heavy as hell though!This quote is hidden because you are ignoring this member. Show Quote
I screwed my boxes down. No lifting those up without removing the batteries anyway.
New (used) trailer for us this year.
https://ibb.co/hvtfpS
https://ibb.co/gzFh3n
https://ibb.co/kdSUin
https://ibb.co/cUSjG7
https://ibb.co/cYOrw7
Was going to post a FS thread but i figured this would get more attention.
I have a couple things i am getting rid of.
- 2 x 6v Napa deep cycles. They read good on the multimeter but were showing their age (3 years) when i pulled them.
- 3gpm diaphram pump
- Shurflo Pulsation Dampner
- Waste water hose (Nice vinyl one, not the free cheapy)
She's a beauty. Some similar touches to my old Jayco.
- - - Updated - - -
How much for that stuff? I'd be interested.This quote is hidden because you are ignoring this member. Show Quote
For all of it? $200This quote is hidden because you are ignoring this member. Show Quote
yep, this, but i also have my batteries inside my basement storage so its more difficult to steal, and i don't remove them, i just hook up an intelligent charger/maintainer all winter because i store at my brother's acreage.This quote is hidden because you are ignoring this member. Show Quote
Gotta get a new BBQ after my current one is essentially a flamethrower since the regulator doesn't work anymore.. Any suggestions (BBQ specifically, not a 'grill')?
if you have a propane "quick connect" on your trailer you could just get a hose and remove the regulator since at the quick connect its already low pressure because its regulated by the trailer'sThis quote is hidden because you are ignoring this member. Show Quote
For pure bbq, Coleman roadtrip
This is what I do. I run a Webber but the concept is the same for any lpg bbq.
Ya i am using a tent trailer, so i keep the BBQ far away from itThis quote is hidden because you are ignoring this member. Show Quote
So I think I need a new battery. Is agm where the best value is? I think 3 years would be a good enough life.
You have room for two 6v golf cart batteries? Generally that's the sweet spot for price vs amp-hours capacity, with great durability.This quote is hidden because you are ignoring this member. Show Quote
This quote is hidden because you are ignoring this member. Show QuoteThis is where its at. Get them from costco. They are priced well and costco will take a return on them pretty much forever.This quote is hidden because you are ignoring this member. Show Quote
the more you know. I just bought a queen memory foam topper from costco. figured it would fit as is. thanks for the headsup.
