Crowchild Tr FYI - Page 7 - Beyond.ca - Car Forums
Page 7 of 12 FirstFirst ... 6 7 8 ... LastLast
Results 121 to 140 of 230
Thread: Crowchild Tr FYI
  1. #121
    Grimace
    Originally posted by rage2
    Hilarious that costs went up over half billion dollars 4 years later, still don't have the money, but whatever!
    Well that is only one library extra so no big deal
    They can just install a permanent speed camera at the new abominable location to pay for the road.
  2. #122
    Bicycle
    WTF just happened?
    Trudeau is in power, we are legalizing pot and taxing the crap out of it. Let's get your wish list in now.
  3. #123
    Nov 2007
    Originally posted by schocker
    I thought that is the cities shtick. Wait until it is years late and way more money with more complexity and then do it.
    And when they do it the proactive way and build something like the airport tunnel when it would be the cheapest and least complex way of doing it people still bitch and complain because doing it that way means you're still spending a lot of money without seeing the benefits for a long time.
    By the time a project has shifted from being early enough to be cost efficient and in demand enough to be politically worthwhile the scope of the project has likely shifted anyway so the process has to be started again and complexity goes up and more stakeholders become involved to drag the process on further etc.
    There may be a cost benefit to doing things proactively but there is rarely a political benefit. You're just making things easier down the road for somebody else while you get all the heat.
  4. #124
    Grimace
    This is why I set anyone straight who dares bring up the tunnel. 'But it goes to nowhere!!!'. They should have just given some firm numbers on what it would cost to build the tunnel under an active runway and with permission from the airport authority at a later date.
  5. #125
    Personally I don't know why they even bothered opening the airport tunnel. Its going to need to be completely redone for the train anyways. How many more millions will that be to venture a guess?
    Every cent that went into finishing and maintaining it is money down the drain. But no council needed it open to show off and brag about their tunnel to nowhere.
    Country hills is literally 60 seconds further up barlow in the meantime...
  6. #126
    N/A
    Y'all might be surprised how much traffic the tunnel is actually seeing - I've used the tunnel regularly for almost the past year and it is most definitely becoming busier and especially so now that 36th Street has seen improvements. I suspect it's being used to avoid McKnight and Country Hills at rush hour - Country Hills will be a non-issue once it's 4 lanes all the way through the NE but who knows how long that'll take.
    Will fuck off, again.
  7. #127
    The tunnel is burning $1.5m a year right now, with costs continuing to go up over the years. The argument isn't that it's cheaper to build now than later (not sure how that math works with ongoing operating costs plus the cost of the interchanges/land purchases which was never included in the first place), but if it was even needed in the first place with Country Hills Blvd being 1.5km away. IIRC the argument was that Country Hills Blvd isn't meant to be a huge throughway, but it's being expanded as such today.
  8. #128
    Nov 2007
    Nothing says proactive planning like having only one E-W connector route between Stony Trail N and McKnight Blvd.
  9. #129
    Nothing says good planning like having 3 of said connectors in a 4 km stretch of a nearly 10km span.
  10. #130
    Not to mention it's not even a true E-W connector. Airport Trail terminates in the middle of the city into residential area.
    Unless we bulldoze Nose Hill and a bunch of communities west of it, we actually can't have another E-W connector through the city aside from Country Hills and McKnight/John Laurie (which also terminates into a residential, but at least on the west edge of the city).
    Here, let's visualize all the possible E-W and see which one makes sense.
    click for larger version
  11. #131
    Stampede Central
    is pretty sharp lookin'
    How do we petition to dig this awesome tunnel idea of mine?
    Not a perfect E-W connector but would save so much time from driving around the hill
  12. #132
    The White Ghetto
    Altima Se-R
    Don't forget the south end where there isn't a E-W connector between Anderson Road and Stoney (formerly 22x). Or, since Anderson doesn't even go entirely E-W, Glenmore to Stoney.
    Approx 6.1km, according to Google Maps.
  13. #133
    Nov 2007
    Already too many in the south with Southland so close to Anderson, no point in adding another.
  14. #134
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I just want them to take the lights out of any w-e road down south, just one
  15. #135
    Isn't that like saying no point adding Airport Trail because McKnight is so close to 32nd?
  16. #136
    Nov 2007
    Meh, all the redundant roads blur together when looking at a map.
  17. #137
    Jan 2006
    Axis powers
    I wish Southland terminated at Blackfoot, would ease so much congestion in that area on Deerfoot
    Sig nuked by mod.
  18. #138
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    So now that the west side is hurting with the Stoney Tr construction I guess the city decided the North commute should hurt too, with the Crowchild Bridge Construction kicking off in the next week.
    I haven't heard or read much about the project other than what I hear on CBC but for awhile I thought they were going to widen crowchild tr from the river up to 16th ave nw? is that not happening now.
    Does the closure of things like the bike path under the bridge affect any of you? To be honest even though I don't live in the North anymore this construction couldnt have come at a worse time considering Sarcee Tr @ 16th is still a mess, they would just need to start doing maintenance on 14th st bridge over memorial to really fuck things up.
  19. #139
    Bunch of Honda's
    Pretty sure they're adding a lane in each direction over the river and changing the location of some of the on/off ramps onto Memorial (to give more space for people merging on/off). Also read somewhere that no lane reductions during construction during the day but I'm sure its going to be a disaster anyways.
  20. #140
    Bicycle
    I don't ride when it hit 0c, so my season really wrapped up already anyway. And if I still want to ride, I can always cross either on 14th (shit show) or earlier at Edworthy Park.
    From what I heard is closure is limited to nights and weekends. Day time will be slowed down and lanes narrowed but not reduced. So I expect crashes when snow comes.
  1. FYI: olsen twins are now 18
    By CKY in forum General
    Latest Threads: 10-04-2020, 11:56 PM
  2. Very Important FYI.......
    By haze4dayz in forum Food and Dining
    Latest Threads: 07-15-2004, 07:54 AM
  3. FYI: New Secret Street Rules. Now IHRA
    By Hollywood in forum General Car/Bike Talk
    Latest Threads: 04-21-2004, 06:57 PM
  4. FYI: There are no cookies! :)
    By kenny in forum General
    Latest Threads: 03-22-2004, 08:21 PM
  5. Exotic Car Show!! fyi
    By Mini Girl in forum Events and Meets
    Latest Threads: 06-15-2003, 11:35 PM
