Vinyl Siding - Can it be fixed? - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Vinyl Siding - Can it be fixed?
    Apr 2005
    Default Vinyl Siding - Can it be fixed?
    So in a move of pure awesome yesterday I managed to chip a couple of small holes (about 3 inch diameter) in the siding of my house. It's right in the middle of the broad side of the house that faces the street so I don't really want to just leave it. If it was out of sight I wouldn't mind so much. Is there really anything you can do with vinyl siding other than replacing it? That seems like overkill for a couple of holes.
    Help?
    Nov 2003
    Calgary Alberta
    BMW, should buy Toyota
    Default hey
    Hey,
    Watch this youtube video. The riveting in a peice may work for you?
    http://www.youtube.com/watch?v=4ch30NCj1b0
    Just depends on how picky you are. Personally I would replace a whole piece but this could work too.
    For some small holes caused by hail I cut 1 foot sections of replacement siding and just slid it over the existing siding to cover the holes. As long as you can find a color match this is the easiest and cheapest way to do it (and I'm sure someone will say least correct), and unless you are standing within 5 feet of the repair and looking directly at it you will never notice it.
    May 2004
    Calgary, AB -- Canada
    I concur with this.
    The hail made one hole in my vinyl siding (actually the vertical trim on the outside corner of my siding) and I elected to glue a 1 foot piece over the hole. As 5.9 stated, you can't tell unless you are standing pretty close.
    Also, to replace the outside corner piece, I would have had to loosen the siding on both walls approximately 4 or 5 feet back from the corner for the entire 8 foot high piece of damaged corner trim. And then, since my siding is 13 years old, that single 8 foot piece of new (slightly darker) trim would stand out way more than the 1 foot patch does.
    Apr 2005
    Replacement (in whole or in part) of the damaged siding would be my first option but the problem is getting a colour match. The house is almost five years old and I've heard that siding companies change colours & patterns often (almost annually). This side of the house get direct sun all day long so even if I had a section of the original stuff (or could still buy it) I'm guessing the colour has faded to some degree and would not match. This wouldn't be such an issue if the damage was on the back or on the other side but this is on the open side of the house (we're on a corner lot) facing the street & sidewalk. Everyone that goes buy is 15 - 20 feet away and it's going to stick out like a sore thumb.
    Nov 2003
    Calgary Alberta
    Default hmm
    Why not take some of the siding off the side that doesn't get seen and put the damaged pieces on that side and then do the patch idea? You will get your color match and the side that isn't seen won't be an issue. This gets rid of both problems-new seams and the color match.
    Apr 2005
    Default Re: hmm
    I can't believe I didn't think of that That's a great idea.
    Can a guy buy siding at Home Depot or some such place?
    Jul 2006
    FJR1300/2018 Giant Trance 3
    Default Re: Re: hmm
    I found the stuff a lowes was a better match to my existing siding.
    335i
    Any other suggestions on where to buy siding? I went to HD and Lowes and the selection wasn't great. I need a color match for about 5 pieces on a 10-year old house. Doubt I'll find a match but its worth a try.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Nov 2003
    Calgary Alberta
    Default siding
    Hey WeaponR,
    You actually have to figure out who made your siding. Vinyl siding isn't as easy as just buying/replacing. Depending on how old your siding is it can be a pain. A lot of the manufactures put their brand on the siding (if you know what a piece of siding looks like it helps) but on the nailing edge you *should* see a brand. Then the best idea is to simply search for someone that supplies that brand in Calgary. Siding can be all different sizes/shapes/profiles so going to a place like Home Depot/Lowes probably won't help you.
  1. Sagiper siding vs LUX siding
    By littledan in forum Home and Garden
    Latest Threads: 02-28-2017, 11:44 AM
  2. Melting vinyl siding vexes homeowners
    By thetransporter in forum Society / Law / Current Events / Politics
    Latest Threads: 11-25-2010, 10:26 AM
  3. vinyl siding
    By oasis in forum Home and Garden
    Latest Threads: 09-08-2010, 07:13 PM
  4. Cleaning Vinyl Siding
    By msouther in forum Home and Garden
    Latest Threads: 08-14-2010, 02:20 PM
  5. LF Someone to repair vinyl siding.
    By mikemechanic in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-25-2007, 11:15 PM
