$$$$$$ Coffee!!! - Page 43 - Beyond.ca - Car Forums
Page 43 of 58 FirstFirst ... 33 42 43 44 53 ... LastLast
Results 841 to 860 of 1141
Thread: $$$$$$ Coffee!!!
  1. #841
    Oct 2009
    rally pig
    getting bored of my Vietnamese drip coffee, might try cold brew with my french press.
    anyone tried this method before?
    https://www.coldbrewavenue.com/how-t...nch-press.html
    going to prepare it today which should be in time for my coffee by tomorrow afternoon.
  2. #842
    That is the exact same method as I described, just with a different container. Some people even use mason jars and cheese cloth. The principles and methods are the same for the most part, you basically just make it like tea that is steeped for a really long time haha. The French press is good because there is plenty of water interaction with the grounds before you decide to push the plunger down and drink it, but it's a little harder to sample the brew before it's done as the grounds aren't contained. You'll also need to grind a little more coarse so you might need a longer brew time to reach your desired flavor.
  3. #843
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    How is that a cold brew and how are you getting water to 150C?
    Science... 150C is warm enough to speed up the process, but not hot enough to release the compounds that alter the taste while comparing cold vs hot brewed coffee
    ...sous vide, personally I use my Anova, mason jars with the lids on loose, have the tops just over the water level, then run it through a metal strainer, then a second pass through a paper coffee filter... usually just use the drip machine’s basket and carafe... smaller batches I’ll use the pour over rig
  4. #844
    Quote Originally Posted by ercchry View Post
    Lack of Science? Sounds more like religion than science.
    Fahrenheit...
  5. #845
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Fahrenheit...
    Whoops, yup Fahrenheit
  6. #846
    I see you mint Farenheit, but that isn't cold brew if you're brewing above room temp - you are pretty much making regular coffee haha. Nothing wrong with that at all though.
  7. #847
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Try it, it’s most certainly not regular coffee
  8. #848
    I've tried brewing around 160F which I don't imagine is significantly different and to my taste it's the same as brewing at 180-190F. Brewing at 40F is dramatically different. All I'm saying is what you're doing isn't cold brew, so it confused me when you called it that, but there is nothing at all wrong with your method.
  9. #849
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I would imagine 160F is releasing many more VOCs than 150F, the compounds that create the more traditional acidic/bitter profile are not present at 150F
  10. #850
    Jun 2004
    Not a fan of cold brew, have yet to try one I like. I prefer cold drip but iced pourover is still the best method for cold coffee.
    I've heard about sous vide coffee. Don't have a device so might try it in a pot or a thermos.
  11. #851
    I'm pretty late to make some kind of joke about ercchry being under a lot of pressure, right?
  12. #852
    No one would underscience it.
  13. #853
    Mar 2009
    Silverado
    I'm also late to the party, but I am buying 5 lbs of five21 coffee for $72. Shows up on my doorstep every 6 weeks.
    Fresh roasted in Calgary
  14. #854
    I'll have to pull out my French press and give it a try. I used to use 160F so I'll try 150F next time and see if I can notice any difference.
  15. #855
    Oct 2009
    rally pig
    just poured my cold brew coffee, got a nice kick on it and actually smooth to drink.
    might make more of this.
    need a bigger french press though as my current one is only a 2cup from ikea
  16. #856
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Aftermath of filtering some 4:1 warm brew concentrate
  17. #857
    Anyone have recs for good coffee, perhaps more freshly roasted that's <$20/lb? We've been buying superstore stuff that's actually pretty decent and inexpensive, but I got a few lb of free coffee from Coast to Coast recently and idk if I can go back to shitty grocery store stuff... but I also don't want to pay >$20/lb.
    Also looking at Costco recommendations for coffee. Had Lavazza Latte which seemed good. Bag is almost done.
    Check out mount pleasant. $10/lb usually roasted 1-3 days earlier. Varieties change daily. Looks like you can order online. I just buy out of the box on the fence.
    http://mountpleasantroastery.ca
    Hmm what's good? You go full Brazilian? Or Honduran?
    Would make a fence joke but probably get cancelled for it.
    @ExtraSlow probably uses F150
  18. #858
    V8s
    I tried to order online, they emailed and said they aren't fulfilling online orders and to buy from the box. My parents live near there, I'll probably ask them to swing by and grab a couple bags soon.
    Even with the subscription discount, monogram is still ~$20/lb (like most other ppl, they ship in 340g bags).
    If the mount pleasant roasters don't work out, I think I'll try the firefighter coffee. Sounds promising.
  19. #859
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    If you’re not picky, eight ounce has sale coffees... tried a few, some had fresh roast dates, others were getting up there... like 3 weeks old or so was the oldest I got?
  20. #860
    ExtraSlow uses F150 water at the glory hole in the fence.
  1. New Coffee Table
    By Dave P in forum General
    Latest Threads: 11-18-2003, 12:31 PM
  2. Bad Ass Coffee Table
    By Gripenfelter in forum Misc. Gallery
    Latest Threads: 08-19-2003, 01:01 AM
  3. Anyone wanna go for coffee?
    By Fuji in forum Events and Meets
    Latest Threads: 02-22-2003, 06:50 PM
  4. Coffee shops
    By szw in forum General
    Latest Threads: 11-25-2002, 12:08 PM
  5. Whois up for a coffee meet?
    By Fluidic in forum Events and Meets
    Latest Threads: 09-01-2002, 05:46 PM
