Hondata flashpro for 06 si - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: Hondata flashpro for 06 si
    Nov 2012
    The obvious
    Default Hondata flashpro for 06 si
    hi guys im a newbie here and im new to the k series honda scene....and im thinking Hondata flashpro for mod, i only have a sri takeda intake for now on my vehicle. Do you think flashpro is recommended?....opinions would be greatly appreciated...thanks...
    " Can't think of anything "
    957,958,NC1,NC3,E90,ITR
    yes, must have. make sure to get a tune too
    Nov 2012
    The obvious
    thanks man i appreicated .....my plan was to eliminate the rev hang, better air/fuel ratio, engage my vtec earlier than 5500 rpm say around....4000 rpm (if its possible) and to have a red line around 8500 rpm....is this possible?...
    Dec 2009
    Slow Injected
    I'm probably one of the few people that doesn't think Flashpro makes that big of a difference if you have minor mods. When I was running just intake and exhaust I unflashed my car to go to the dealership and left it unflashed for a couple weeks after that because I didn't really miss it.
    I think the dealership updated my ecu during one of my visits and got rid of the rev hang because I didn't notice it while it was unflashed.
    And yeah it is possible to do all of those things you posted.
    ^were you using the hondata basemaps or did you get an actual tune? i found there was a huge difference.
    Nov 2012
    The obvious
    i see thanks.....cause im planning on purchasing one and when i was doing my research on the reviews of the product...there's quite a lot of people are satisfied and happy about the outcome of it....im looking for a use one that is unlocked but i can't seem to a used one here in calgary....i'm not aiming for something drastic sky rocket increase of hp (which would be nice ) but something moderate. But i still want my vehicle too last long, less maintenance and i can drive it daily with no hiccups....
    Dec 2009
    Slow Injected
    Yeah I'm still running a base map, gonna get an e-tune in the spring or summer. Does the tune makes that big of a difference? I thought it would help squeeze out a few extra hp's and just help the car run smoother overall but didn't think it would be anything too crazy.
    Jim, are you still looking for a used Flashpro?
    Jan 2005
    canada
    z32 2+2
    i am acutally looking for a used flashpro if anyone has one for sale
    MooooooO
    AWD grandpa wagon
    Even running a tuned stock Si, it greatly increased the throttle response and made the car smoother.
    When I ran K-pro on my RSX-S I found the difference between the base map and a actual tune off a dyno was a noticeable difference. I figure if I was going to spend all that money on a programmable ECU (or in your case the capability to program it) might as well run a map that is optimized for our location.
    Jan 2009
    CNG Injected
    you would be wasting your money doing the flash just for intake.... I would do drop in cams an header then dyno tune to really notice a different :
    jump on k20a.org and 8thcivic.com you will find more info on those websites then anyother forum
    Dec 2009
    Slow Injected
    Where did you go to get a dyno tune and how much was it?
    Got mine done by Matt at Tecmotion. He charges a flat rate after a certain amount of hours on the dyno. It ended up being ~$550 but we did a bunch of runs figuring out why my numbers i was getting off the dyno were low (turned out to be a blocked cat converter ) so im sure if your car doesnt have any issues it would be less. He's done a few K20's before.
    He's not the only guy tho, im sure Toma could help you out as well with a good tune.
    Aug 2004
    N/A V8, TTV6, DOHC N/A V6
    Jeff Evans E-tuned mine for 200 bucks.
    14 datalogs later and my car runs fantastic.
    Search e-tunes, or go to Evanstuning.com
    -H.P. Lovecraft
    just get an etune, with your mods there won't be a difference. jeff tuned mine as well
    Aug 2002
    You Crazy
    That's a lot of cam angles to play with, and tables to tweek for an e-tune.
    Is he at our elevation? Are your cam angles optimized for 4000 feet, Ambient air at 88kpa, your intake system, and your exhaust?
    Ditto Spark timing and AF? Or was it tuned to a generic, "usually make the best power" number?
    How did he find MBT timing without having the car on the dyno?
    A dyno tune is best, but on a K-series will cost $400 to $500. Either Anthony or myself can help you out.
    $500 dyno tune is a little extreme when all he has is an intake, etune is fine this his case...
    Aug 2002
    You Crazy
    And $200 for an "e-tune" is ok??
    E-tune if you provide logs takes all of 5 minutes. No effort, no strapping a car down, no testing.
    What exactly are you "tuning" with an e-tune?
    Set the AF to 13:1, and call it good?
    You are just cheap lol
    I look at it like this. Flash Pro + e-tune = ~900. Flash Pro plus dyno tune, ~$1100. realistically, is it THAT different given the total investment in this one mod?
    Nov 2012
    The obvious
    hi guys ...sorry i was gone for a little while...and yes im still looking for a hondata flashpro....there's quite a few opinions here which i really do appreciate thier honesty, You guys are really knowledgable about this product, me on the other hand is a newbie. .....i guess my main goal is not drastic hp...i just want to have that early vtec sensation, no rev hang, a little higher rev limiter and a good a/f ratio....my question is now....is it really worth it to have a hondata flashpro with my goals?....as for me i am really interested on purchasing one...
  1. FS '12-'15 Hond Civic SI Hondata Flashpro
    By KaJeR in forum Automotive Parts [Engine Electronics]
    Latest Threads: 10-04-2015, 12:52 PM
  2. Fs: Hondata Flashpro
    By +AsiaN+ in forum Automotive Parts [Engine Electronics]
    Latest Threads: 03-13-2013, 04:57 PM
  3. FS: Hondata FlashPro for 2006-2011 Honda Civic Si
    By gyu in forum Automotive Parts
    Latest Threads: 01-02-2013, 02:19 PM
  4. 06-09 Civic Si Flashpro Local Tuners
    By Darkane in forum Honda Owners Club
    Latest Threads: 08-29-2011, 05:10 PM
  5. WTB: Hondata FLASHPRO for 2008 Civic Si
    By Darkane in forum Automotive Parts [Engine Electronics]
    Latest Threads: 07-22-2011, 08:01 PM
