Hot water tank issues - Page 6 - Beyond.ca - Car Forums
Page 6 of 6 FirstFirst ... 5 6
Results 101 to 117 of 117
Thread: Hot water tank issues
  1. #101
    Dec 2004
    YYC and YVR
    You could rent a hotel for a couple nights and still come out ahead.
    Yeah back then when my wife wasn't a porkchop like now, could've driven to banff and back, stayed at the banff springs too hahaha
    Ya maybe a poverty hotel. Like 4 star, ewww.
    Hey hey, we're rolex owners, give me some credit
    On another note, looks like I made a post about my Rheem hot water tank here in Nov 2015 and it costing $1008 from Pete blah blah, so Looks like I'm roughly 1.5 years I'll be posting an update that I got another Rheem from Pete for $xxxx.xx hahaha
  2. #102
    Oct 2013
    Red Deer
    Bikes.Car.Truck
    Wife text me a couple nights ago. Said she ran a bath and there was no hot water. Only lukewarm at best. I was away working so I FaceTimed her and ran a start sequence on the hot water tank. It did its normal start and ran but then cut out. I had her take the thermostat down to minimum and close the gas valve until I got home.
    Got home this morning and turned the thermostat to max. Heater ran as normal. Went to downstairs bathtub and turned faucet to max hot and only got lukewarm water. Went back to the tank and set my sights on the thermostatic mixing valve. Hot water piping into the valve was very hot. Cold water in was cold, but the outlet was just barely warm. There's the problem. Valve is stuck. I did a quick google search which showed many others with the same problem. I tried turning the valve by hand but it was seized, a problem that another's also had lol. There was a plumbing video that showed a plumber take the cap off and grab the brass fitting with a pair of channel locks. I used vice grips and with just a little bit of force, I was able to break thru the resistance and then I was able to turn the valve by hand throughout its entire travel. I kept the tub flowing and cycled the valve. Set it back to hot and tested the water temperature at the tub. Tempered hot water is back and flowing beautifully to all faucets throughout the house now. Easy 5 min fix.
    Tank is a 50USG Polaris PR50-130-2NV. Condensing type and stainless steel. Never seen one before. Was manufactured in October 2022 and installed by previous owners sometime in early 2023. I originally thought I was facing a flame failure due to a smoked ignitor as these tanks have their ignitors double as an electronic flame sensor but she was all good.
    Honeywell AM-1 Series thermostatic mixing valve. Another quality Honeywell product! I guess it could be worse.... Most people change out the guts on these things with a rebuild kit, a task that is very likely to be in my future.
    The heater had been running and supplying us with hot water since we moved into the place in June. But I found that it would cut out before it got to its temperature setpoint. Not sure if it was hitting its ECO or not but I decided to break into the combustion air supply piping to find the air filter that these units ship with. Yah..... the filter was a touch on the dirty side lol. Cleaned it up and no more early cut outs since!!!
    Looking around
    Wondering what became
    Of what I once knew
  3. #103
    Damn, nice job man!
  4. #104
    Is there a reason that the mixing valve is needed? Isn't that what the temp dial on the tank already does?
  5. #105
    Oct 2013
    Red Deer
    Bikes.Car.Truck
    Scalding code I think. The tap on our ensuite bathtub is split... one tap for hot and one tap for cold rather than having a mix at the tap like most faucets I've dealt with. Needs to be a mixing valve to prevent scalding from the hot tap. But I'm not 100% sure, this was what an HVAC guy was telling me a while back...
    Looking around
    Of what I once knew
  6. #106
    Oct 2006
    Z
    Tankless. It's the only option
    Z32 TT
    1996 Integra - winter beater with studs - RIP (deer)
    2002 WRX - to be sold
    2010 sti - winter
  7. #107
    Mar 2014
    I'm in a similar boat. Deciding to convert my electric water to the following options:
    1.Tankless gas
    2.combi boiler
    3.hybrid electric and venting a hot air supply to it for more efficiently
    https://www.hotwater.com/products/pr...100361834.html
  8. #108
    Mar 2011
    Calgary/Alberta
    I don't think it is general code - but not a plumber. My house had that when we bought in because a previous owner ran a dayhome out of the house.
    It had failed at some point so when tank was set to max temp to actually get warm water from the taps. Was looking at a replacement tank - and negotiated the cost into the sale of the home - but plumber suggesting trying to remove the mixing valve first and it fixed it so we could set tank to normal temp.
    Of course tank ended up failing a couple of years later anyways - guessing it shortened the life being at max temp for a few years.
  9. #109
    I know what the valve is for. Just seems like a redundant system that is unnecessary. Unless as a human you struggle to mix hot + cold water at the tap, of which then there are bigger issues.
  10. #110
    Canyonero
    I'd always assumed it was to increase the effective capacity of your domestic hot water. eg. if you store 50gal of water at 120F, versus the same volume at 160F, you would need less volume of hot water, for the same output temp at your fixtures. ¯\_(ツ)_/¯
  11. #111
    Doesn't the thermostat on the tank do that?
    "highly soup-motivated"
  12. #112
    It's because too many people burnt the shit out of their kids because they were terrible parents and didn't pay attention to how hot the water was when filling a bathtub.
    Pretty much the reason we have most modern codes. Stupid people doing stupid people things ruin it for the rest of us.
  13. #113
    yeah.
  14. #114
    But how can we extract the money from these stupid people?
  15. #115
    Apr 2007
    GLS63 AMG
    Pretty cool tank, we had someone call in for one of these with an ignition error tonight actually, super uncommon hot water tank. I've only seen one before and it was a few years ago, had to replace the ignition control board and it needed to be air freighted from Ontario as no one stocked parts for the thing.
  16. #116
    Apr 2007
    GLS63 AMG
  17. #117
    Oct 2013
    Red Deer
    Bikes.Car.Truck
    Quote Originally Posted by StreetRacerX View Post
    Yah I’m kind of dreading the ignition problems that will inevitably come. Does the ignition control board being a black box next to the main board ring any bells? Everything is underneath the tank so you pretty much need to lay on your stomach or side to work on them.
    Very, very expensive tank too!
    Looking around
    Of what I once knew
  1. Hot Water Tank Issues
    By Feruk in forum Home and Garden
    Latest Threads: 03-17-2017, 12:06 PM
  2. LF: Plumber, New Hot Water Tank, Water Softner
    By Env-Consultant in forum Home and Garden
    Latest Threads: 11-06-2014, 11:22 AM
  3. Please service my Hot water tank-no hot water!
  4. Hot Water Tank, no hot water.
  5. Need hot water tank repairman
    By gonefishing in forum General
    Latest Threads: 06-20-2007, 12:25 AM
