Can't find central vacuum outlet - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Can't find central vacuum outlet
    Subaru Outback
    Default Can't find central vacuum outlet
    I have a 12 year old house.
    There is no central vacuum installed.
    On the upstairs, and downstairs floors, there are blank panels on the walls, and behind them are outlets for the central vacuum. I can see a pipe running down from the upstairs and the downstairs pipe also runs downstairs. I'm guess the house was roughed in for a central vacuum.
    However, I can't find the "base" outlet where the cannister would go. I've looked all over the garage and the basement (which was developed a few years ago). I'm thinking the dingbat who developed the basement may have put drywall over the base panel.
    Does anyone have any suggestions as to how I could figure out where the base panel is? I thought about using a plumbing "snake", but they are quite big in diameter and have read they can damage the thin walled plastic pipes.
    has anyone ever seen a thin gauge "snake"?
    Any other ideas?
    THanks
    James
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    fish tape?
    go till you hit something, get someone to move it around till you can hear it in a wall?
    Nov 2005
    Hondas
    big ass washer tied to a string should do ya
    Jul 2011
    My house was roughed in when I bought it 4 years ago. Pipes ran straight down and then just ended in the roof of the basement, you could look straight up them. I had to run all the elbows and horizontal pipes to the canister.
    If they did nothing to the piping I would suspect the same except they dry walled over everything with the roof.
    Could be wrong, hope so for your sake.
    Try the washer or wheel nuts on a string and listen for where it hits.
    Nov 2007
    Cowgary
    AWOL
    I have a golf ball on a string you can borrow
    Jan 2009
    As suggested, grab a fish tape at Home Depot
    I'd vote for him. America may have a black guy, but we'd have captain fucking Kirk.
    Oct 2006
    oooo
    The PVC pipe will only be stub downs. They do not go to your mechanical room.
    They are almost always directly below the blank off plate in the basement and almost never on outside walls.
    You will have to do all the plumbing yourself in the basement.
    2017 VW Jetta 1.4T (winter car)
    2010 F-350 Nortruck Tool Shed
    2007 BMW 5 (Wifey's)
    2004 Audi A4 1.8T 6spd Stage III w/ Meth
    1985 F-250 6.9L IDI w/ATS turbo
    As sillysod has said there would be no 'base' connector in the basement unless the person finishing the basement connected this all together.
    Mar 2008
    Busa
    Default Re: Can't find central vacuum outlet
    Yup, that's exactly what they did.
    You can hook a line tracer up to the power line they ran with the PVC, and that should allow you to trace exactly where it is behind the drywall.
    Subaru Outback
    Thanks for all of the suggestions.
    I'm going to buy some of the fish tape that was suggested and see how that goes.
    James
    Jul 2006
    FJR1300/2018 Giant Trance 3
    When I had to find mine, was run alongside the cold air return throughout the house. The end of mine was inside the cold air return duct at the bottom of my stairs. It was pretty much the last place I looked.
    Dec 2004
    Vmax
    Compressed air into the tubes. Should be able to hear hissing from behind a wall?
  1. FS: brand new carpet pro vacuum(commercial Vacuum)
    By Dren in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-12-2012, 07:41 PM
  2. where can i find a vacuum pump in calgary?
    By riceeater in forum General
    Latest Threads: 11-07-2008, 11:12 AM
  3. FS- central vacuum systems
    By dropdat in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-11-2007, 05:57 PM
  4. Central Vacuum System
    By Boost Infested in forum General
    Latest Threads: 09-11-2007, 09:00 PM
  5. Central Vacuum
    By sgouki in forum General
    Latest Threads: 05-23-2006, 03:16 PM
