I'm lost and need some help from the gurus on here! I'm trying to set up my VPN router behind my regular router, and I'm really struggling.
First off the setup is cable modem --> Asus RT-N56U --> Cisco E2500 w/dd-wrt BIG installed running the VPN script from Hidemyass.
The Asus will remain a local address machine, as its not VPN capable, and I'd like to keep a local anyhow for some devices. It needs to share its connection with the Cisco through its LAN ports. I'm led to believe that this can be done using the "LAN-route" portion of the Asus router. At least it says thats for connecting several routers to the internet behind the Asus using the same connection.
Problem is, I have no idea what to enter into the fields, they are:
Network/Host IP, Netmask, Gateway, Metric, and Interface (LAN).
First things first, the router names are not the same so there is no conflict (Asus is 192.168.1.1, Cisco is 192,168.1.2). The Cisco will see the internet and route if its connected to the modem, as will the Asus, independantly. But if I plug the Cisco into the Asus, the Cisco doesn't even get assigned an address?
Any advice????
