GM Voids Warranty because GMC Terrain owner changed own oil - Beyond.ca - Car Forums
Page 1 of 7 1 2 ... LastLast
Results 1 to 20 of 125
Thread: GM Voids Warranty because GMC Terrain owner changed own oil
    Okotoks North
    Default GM Voids Warranty because GMC Terrain owner changed own oil
    http://www.globaltvcalgary.com/consu...707/story.html
    CALGARY- Changing your own oil is a great way to save money on vehicle maintenance, but it could actually cost you more in the long run.
    Chayne Culig got a 160,000 kilometer Powertrain warranty on his GMC Terrain truck, which came in handy when an engine seal blew and the motor had to be replaced. But he ran into trouble with the automaker when he tried to get them to cover it.
    That’s because Culig, a heavy duty mechanic, had changed the oil himself, so he didn’t have any receipts to prove his vehicle was regularly maintained.
    “I will be taking them to court,” Culig says. “I have no choice in the matter, because it’s quite costly and I’ve had a lot of repairs on this vehicle since I’ve owned it.”
    GM Canada would not explain the reasoning when contacted by Global News, but said in a statement:
    “We encourage customers to keep detailed receipts of their maintenance and history, including kilometers or any other issues found at the time of maintenance. Without this information, the manufacturer is left to take into account only the information they have available when determining what caused the issue.”
    Phil Edmonston from the Lemon-Aid Car Guide says consumers should be protected in cases like this.
    “The onus of responsibility is not on the victim, it’s on the seller of the product, and that’s the way it should be.”
    Culig replaced the engine himself for about $2,000—$5,000 less than the dealer quote.
    Any GMC Terrain owners on here? Curious if the owners manual or Warranty information requires that one keep records of any maintenance as part of the warranty agreement.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    when my engine popped, ford wanted receipts even though all maintenance was performed at ford dealers... you'd think they would have a system for that
    Aug 2012
    CGY
    I've heard of this before.... dealerships often use the "u void ur warranty if u do ur own oil changes" line to get ppl to pay their shop rates (if u dont get free oil changes thrown in on the deal)
    but ive known ppl where they keep records and receipts (apparently theres even a section at the end in the owners manual itself) and the dealership can't deny warranty service? Not sure if its true or not, but i'll figure it out if i every buy a new car from a dealership in the future
    It would make sense though that the warranty stipulated that any maintenance work performed would have to be backed up by receipts/records... Otherwise u could just not change ur oil at all and then when the engine goes, get a new one
    mars
    Default Re: GM Voids Warranty because GMC Terrain owner changed own oil
    Not a Terrain, but page 22 of the warranty manual for our 2012 GMC van says
    "Retain receipts covering performance of regular maintenance. receipts can be very important if a question arises as to whether a malfunction is caused by a lack of maintenance or a defect in material or workmanship"
    It was a while ago that there was a court that ruled that receipts for suitable quality and quantities of oil and filters as well as the owners own records of when and odometer readings were enough to establish that the required maintenance had been done in a similar case. But I think this guy is SOL 'cause he's got nuthin'.
    Dec 2006
    Nothing worth mentioning.
    Fuck GM. They've lost me as a long time customer. They're just shitty with EVERYTHING.
    X5D, Fiesta ST
    Yes you must provide reciepts that show the type of oil you use, filter type used, and on the reciept you should write both the day and mileage of when you performed your oil change.
    I work for GM and if we have major failures we expect to see these records otherwise you are shit out of luck. Even if it is done at other dealers if it isnt warranty oil changes (Cadillacs) then we need to see the records and proof to provide warranty.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Originally posted by EK69
    it would make sense though that the warranty stipulated that any maintenance work performed would have to be backed up by receipts/records... Otherwise u could just not change ur oil at all and then when the engine goes, get a new one
    the onus would be on the company to take oil samples. test them. take the motor apart, find the failure... then come to a decision if it was due to neglect, design, or defect... but just saying no is easier
    Don't buy a new vehicle unless free lifetime oil changes are included.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    and why is that oh wise one?
    May 2007
    '19 GTI
    Why not just keep reciepts for oil+filters? Gonna be hard to prove he "diligently maintained" his vehicle otherwise, mechanic or not.
    I believe Mercedes in the US requires you to go to the dealer, show your receipts and they will stamp your book for you with the current mileage. It's a free service if you decide to go elsewhere, or DIY. I'm not sure how Canada works.
    If this guy has absolutely no receipts, he's not going to get anywhere. Keeping receipts is not only common sense if you DIY, it's required in pretty much all the maintenance booklets. I'm sure they're all written by a bunch of corporate lawyers for cases like this haha.
    Aug 2012
    CGY
    my buddy says volvo oil changes cost him around a couple hundred or so each time (i cant remember exact numbers, but they made places like Mr. Lube seem cheap)
    AB
    16' Tacoma Offroad
    What is the point of this? Of course he got denied, he should know better. Extended warranty wants evidence of maintenance. 3 year 60 there is no issue.
    Dec 2006
    My avalanche goes through 4L of oil in 5000 KM. GM asked for all my shit. I provided it. They did nothing. Too bad.......
    So the only way I can punish GM is to never step foot in their dealer again. The 5.3 is pure garbage.
    X5D, Fiesta ST
    Don't get mad at me, I didnt design, build or make the calls on your vehicle. What year of Avalanche is it and how many km are on it? Have you had a GM dealer fill out a oil consumption sheet and brought it to them to have them check and top up the oil level?
    May 2010
    8P 3.2
    If he did not change the oil wouldn't it be pretty obvious once they crack the engine open? I have seen a dead engine die to no maintenance and it was pretty messy.
    Dec 2006
    I would never get mad at you. I've done all the necessary crap had the recall done. Still runs through oil like Druh Farrell runs through crazy.
    They're just shifty buggers. I'm just publicly venting over my poor choice in vehicle. Oil is cheap. I'll run this truck until it dies.
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    Terrains and acadia require a semi to full synthetic oil and an OEM Oil filter, there are
    Currently a few service bulitins regarding non gm filters and blown engines.
    The issue is the high oil flow rate through the filter causes the filter substrate to get pushed into the heads oil galleys and plug them up.
    X5D, Fiesta ST
    All GM vehicles model year 2011 and newer require semi synthetic or higher for oils. 2010 and older generally only Cadillacs, Corvettes, and 2010 Camaros require synthetic.
    May 2007
    '19 GTI
    Ive always brought my truck to GM to have oil changes... Usually around the $60 mark for a 5.8.
    It works out to be about the same price that i'd pay to do it on my own, + a little i guess.
    Worth it to me.
  1. GMC Terrain Nightfall Edition Hits New York Auto Show
    By rage2 in forum Automotive News
    Latest Threads: 03-24-2016, 10:40 AM
  2. Replies: 55
    Latest Threads: 02-24-2013, 02:56 PM
  3. GMC all terrain concept: GM's Raptor competitor
    By corsvette in forum Automotive News
    Latest Threads: 01-27-2011, 01:40 AM
  4. Dust VOIDS PS3 Warranty
    By 06civic in forum Video Games
    Latest Threads: 04-11-2009, 03:28 PM
