Hardie Plank Siding - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 45
Thread: Hardie Plank Siding
    Dec 2003
    Cowtown
    02 Blown X
    Default Hardie Plank Siding
    Does anybody have experience with James Hardie plank cement fibre siding?
    I have been thinking of using it on my shack but have read mixed reviews. Trying to decide if it is worth the extra cash.
    calgary ab
    4x4
    No personal experience...
    Down at the bottom of ridgeview place in cochrane you can find a bunch of houses with it... Have a good look down the sides - check the waves...
    If it was me - it'd drive me nucking futz; but I'm a little OCD when it comes to lines.
    Dec 2003
    Cowtown
    02 Blown X
    I will have to check that out, thanks.
    My shack is not new, so I'm sure it is far from straight and true also.
    I have read you can avoid the waviness with a quality install and shim it out
    2011 BMW 335is Cabriolet
    My entire house and garage are Hardie and I see a few very small waves but by no means is it unattractive. It all depends on your framing. I higher advise people using it vs vinyl. Vinyl looks like shit and is cheap looking. Just my opinion but for our house it was only around $6k extra over vinyl. It gives a good fire proofing too. I don't have a negative thing to say about it. If your looking at Hardie check different neighborhoods to get a good idea what it looks like installed. I will try to throw up a couple pics of my house for you tomorrow.
    2011 Lexus RX 350
    Nowhere
    Jun 2004
    90 DB1, 03 RL1, 07 YK1
    ^^The standard colour selections is somewhat lacking, but it can be custom coloured if you are willing to pay the premium.
    As far as the waviness goes, a good part of it depends on the colour. If it's a darker colour it tends to show the waves a bit more than lighter colours. I'd still take a little bit of waviness with Hardie over vinyl siding though.
    Taco
    I thought Vinyl only cost $3-$4K ish to do standard house. Thats a decent amount more. I could be way off on the price of vinyl though, I just googled it when I considered replacing my siding.
    Jun 2004
    That'll probably cover just the labour on about 2500 sq of wall area. Depends on the size of house you're talking about. 2500 is the average wall area of most newer homes.
    Jun 2003
    YWG
    Just put Hardie (iron grey) on my 1956 bungalow.
    It looks awesome.
    I have no waves at all. However I also have 1" foil back insulation under it as well.
    calgary ab
    4x4
    I'm 100% sure install has a lot to do with it (like almost anything) - but, from what I've seen, there's some "variation" in the hardie product. Which can appear to be vertical and horizontal waves.
    The extra cost can be justified in new home, where they're starting to require fire ratings. One of the big things for me is the siding appearance, fire rating and hail resistance. It's definitely an attractive product in a number of ways.
    Any product, it's best to go out and see real-world installs. Just my humble opinion.
    Jun 2003
    YWG
    Another benefit of Hardie is that you can paint it.
    Dec 2003
    Cowtown
    02 Blown X
    Thanks for all the replies! This really helps.
    For everybody that has hardi board, how long have you had it for? Was it pre-finished or painted on site? How has it held up so far?
    I would really appreciate that.
    It looks awesome.
    This was my next question as I am also thinking of putting some foam under the siding. I see that the maximum hardi recommends is 1" of foam. However, to create a thermal break to prevent moisture build up on the sheathing I figured I need about 1.5" of foam. Did you do anything special to accommodate for this?
    Jun 2003
    YWG
    Mine went up last October.
    The horizontal planks were pre-finished and the corner and window moldings were painted onsite. The caulking used is colour matched as well.
    Looks great so far.
    Dec 2004
    ecoboost
    I've had Hardie board for 5 years now, we've had zero issues and it looks way better than vinyl. Ours was pre-finished brown. If we build another home I wouldn't hesitate to use it again.
    Nowhere
    Elbonia
    Jeep of Theseus
    We just finished replacing all the poorly-installed vinyl siding at our condo complex with Hardie, it's pretty solid stuff, especially compared to the flimsy-assed vinyl. Nice that it's paintable as well.
    Dec 2003
    Cowtown
    02 Blown X
    I'm surprised there are so many people using it, this helps me decide for sure. Sounds like a solid product.
    After the last big hail storm, I"m not at all interested in putting up vinyl. I currently have aluminum in a nice yellow / green 70's color.
    Anybody have any experience with foam under the siding and moisture problems?
    This article suggests a minimum thickness in order to avoid moisture build up. Link
    Jan 2009
    Looks great so far.
    Whats the sq/ft of the house? Did you do the install yourself? How much did it cost? I suspect we've got similar houses. Gotta do my 1200 sq/ft bungalow sometime and I'm torn between the foam backed vinyl siding or hardiboard.
    Sep 2008
    Edmonton, AB
    I was just about to ask that! Mine's about 1300 sq/ft and it will need to be done in the next couple of years...
    However I also have 1"; foil back insulation under it as well.
    Did you notice any difference in comfort and a lower heating bill with the foil?
    Originally posted by Xtrema
    Originally posted by DayGlow
    How do you respond to stupid?
    Originally posted by rage2
    Originally posted by Seth1968
    Apr 2003
    '03 S2000
    A friend of mine used to do the lab portion of the Civil and Architectural programs at SAIT - where they build the house each term.
    All those houses built at SAIT have used Hardie Board and he swears by it. Very durable - 15-20 yr. warrantee although you can get some fading in the sun. The installation is more labour-intensive due to the weight of the product (it is concrete after all) and, hence, more expensive.
    But it is solid ... will stand up to hail much, much better than hail.....and better for a fire barrier when your neighbour's house is burning down.
    I looked over the last house they built in the fall and it appears to be a good product. Basically, you get what you pay for.
    R
    "I don't look for something; I find something" - Picasso
  1. Sagiper siding vs LUX siding
    By littledan in forum Home and Garden
    Latest Threads: 02-28-2017, 11:44 AM
  2. Hardie Board - Exterior Renovation
    By 2000Accord in forum Home and Garden
    Latest Threads: 10-11-2016, 02:12 AM
  3. Post A Plank
    By dj_rice in forum General
    Latest Threads: 07-26-2011, 06:36 PM
  4. Federal Liberals cap and trade election plank raises questions
    By derpderp in forum Society / Law / Current Events / Politics
    Latest Threads: 04-04-2011, 04:27 PM
  5. what is the best fish for cedar plank grilling?
    By nonlinear in forum Food and Dining
    Latest Threads: 06-23-2009, 12:20 AM
