Ford Trucks Thread WAS:EcoBoost Thread - Page 101 - Beyond.ca - Car Forums
Page 101 of 257 FirstFirst ... 91 100 101 102 111 ... LastLast
Results 2,001 to 2,020 of 5122
Thread: Ford Trucks Thread WAS:EcoBoost Thread
  1. #2001
    Sep 2007
    golfR
    Quote Originally Posted by Proyecto2000 View Post
    Well it looks like my cold start rattle has now returned and I have to bring the truck back in. Did I really go through a brand new set of cam phasers and whatever they installed on the truck in under a week?
    Also the annoying auto start stop seems to longer be functioning properly as all the time my screen shows engine on due to low temperature.
    Where in the screen do you see this?
    Is this new for the 2018/2019?
    Mine is a 2017.
    Quote Originally Posted by Rocket1k78 View Post
    Had Universal do my cams and they treated me well. The repair was quoted at 2-3 days so i rented a car through them for the 3 days. It was supposed to be done on the friday but they called me early to say it wouldnt be done til monday or tuesday. I asked if they would cover the rental for the weekend and he said no at first but when i pressed a bit more he said they would. I had read about guys having this done and then having oil dripped on the driveway from them not cleaning it up but not 1 drip on mine
    If it makes you feel any better you're not the only guy that had them replaced only to comeback. Theres a bunch of guys that went through this too on the f150forum. Theres supposedly a new fix coming out soon
    Had mine done at Universal as well. Initially quoted 2-3 days as well but due to parts being delayed they had it for a week. Didn't charge me a dime for the rental. I didn't even ask, they just gave me one at no charge and nothing was paid at the end.
    I should keep at an eye on mine, hopefully it doesn't come back since it's now out of warranty.
  2. #2002
    May 2004
    Cayman
    Well I knew the rattle would eventually happen again as they replaced the worn out parts with the exact same new defective part that was bound to fail just didnt expect it that quickly lol.
  3. #2003
    May 2004
    Cayman
    Quote Originally Posted by chongkee_ View Post
    Mine is a 2017.
    On my 18 I just scroll over into the engine auto off menu on the dash. When you are driving the message reads normal engine operation or something like that and when you stop it either says engine turned off or engine on due to low tempature which mine reads all the time.
    You will also see that the A with a circle by the odometer turns grey which means that the engine isn't turning off. Normally it goes green when off or orange when you disable the auto on/off with the button.
  4. #2004
    Jun 2014
    How long ago was that? Universal hooked me up with a rental no prob last year on some recall work and they used to cover the shuttle rides back and forth but this year they only covered the ride back to my shop and i was on my own to get back.
    Sucks that we all knew it could come back but that quick is brutal. If you're on the f150 forum search the threads, theres one about this and the guys are saying a new repair is coming out i think
  5. #2005
    May 2004
    Ford, Acura
    Quote Originally Posted by AllGoNoShow View Post
    Maclin is a shithole, avoid at all costs in my books. I actually haven't had any major dealer repairs in town that didn't have to go back a second time... very sad.
    Maclin has been the most brutal dealership to work with and I've yet to hear a good story coming out of their operation. Trying to buy a vehicle from them was probably one of the shittiest experiences I ever went through. The only reason my buddy went there was because after calling around they were the only ones to say they could have the work done in a week.
    I'm generally cute.
  6. #2006
    Jan 2006
    GR Supra MT, MK8 Golf R
    I've been checking this thread periodically as there's mention of a TSB from Ford that's supposed to be out Q4 2019 but I haven't seen anything yet. According to said thread the cutoff for trucks having the cold start issue vs not having it is a build date of July 10th, 2018:
    "Affects: Some 2017-2018 F-150 vehicles built on or before 10-Jul-2018
    Some 2017-2018 F-150 vehicles built on or before 10-Jul-2018 and 2018-2019 Expedition/Navigator vehicles built on or before 8-Apr-2019 equipped with a 3.5L EcoBoost engine may exhibit a ticking, tapping, or rattle type noise from the top front cover area of the engine that last 2-5 seconds on initial start-up after a cold soak. This may be due to a worn variable cam timing (VCT) unit. A TSB is expected to be published 4th quarter of 2019. In the interim, replace all 4 VCT units and update the powertrain control module (PCM) calibration. Do not replace timing chains, tensioners, guides or other timing related components unless inspection clearly identifies a concern. Refer to the Workshop Manual (WSM), Section 303-01. Claim the labor required to replace VCTs using published labor operations and PCM programming using M-time. Monitor OASIS for updates.
    However there's been guys with 2019's with the noise and my truck which was built after that date also makes an annoying noise on cold start, though I've also had a heck of a time trying to confirm whether or not my noise it is in fact the same issue or not.
  7. #2007
    Sep 2007
    golfR
    Thanks! I see them now. I'm aware of the circle but not the menu showing why it's not activating.
    It never really bothered me but was always curious the reason why mine rarely activates. I always knew that it was probably my battery since it never gets really charged since the truck is only driven a couple of times a week the last couple of months. Nice to get confirmation.
    I posted on this thread when I had it done, I think it was at the beginning of the year.
    They gave me a rental since the the work requires more than a day.
    I dropped off the truck and the SA told me that they'll need the truck for more than a day and to head over to the rental desk.
    For regular service like oil changes it's always been the cab the last two years I've been going there.
    Cab from the dealership then on my own to get back.
    Last time I had service done back in September the car driver told me that the ride back is covered now too but didn't bother with it to find out.
  8. #2008
    I've said it before, but if you can, it's really good for the health of your battery to connect it to a maintainer overnight once a week or anytime it's going to sit more than a week. Now, you may not be having a catastrophic no-start situation without this, but it'll extend the life of your battery, and let the vehicle operate more efficiently.
    I use this to make the process easy.
  9. #2009
    Sep 2007
    golfR
    Thanks for that. I should start doing that.
    The connector would definitely make it more convenient.
    Any recommendation for a maintainer?
  10. #2010
    CTEK /thread
    I think Slow likes the Noco genius
  11. #2011
    really, any "smart" charger should be fine. CTEK and NOCO are good. Even battery tender or some of the better motomaster brand is fine. I found better deals on the NOCO 7200 when I was shopping.
    If you just want a maintainer, you don't need many amps. I have a battery tender Jr on the wall of my garage where my wife parks, and it's 0.75A, and totally sufficient for overnight or storage maintenance.
    - - - Updated - - -
    Sale on this one at triangle store, it's got enough amperage that it will charge a dead battery too, and comes with the quick-connect eyelets:
    Name:  Noco Genius.jpg
  12. #2012
    Sep 2007
    golfR
    Ordered the Noco 3500 from Amazon. Thanks!
    Can't justify getting the 7200 since I don't really need the extra features it has over the 3500.
  13. #2013
    Handy to have around. install the quick-connect and hang the charger on the wall near where you park. Plug it in lots in the winter, and occasionally in the summer, and live your best life.
  14. #2014
    Nov 2007
    Your Mom's House
    update:
    I had the cold start rattling timing chain & cam phaser issue resolved as however the truck started to run hot and the engine fan went into over drive so they also replaced the radiator fan motor & thermostat.
    I am very happy with the service and how I was treated at Cam Clark Airdrie so I would highly recommend them for the engine work if any of you experience the cold start rattle. I went over the engine bay and underneath and every clip and plastic pin was replaced and you cant even tell that they took this truck apart.
    My engine fan is going into overdrive but their "testing" didn't find anything. Apparently I have to drive there while it's going nuts and have someone come out to look at it. Hard to do with the weather lately. The fans calm down in this cold, but in the heat they'll continue to run full blast in idle while I'm trying to figure out wtf is going on.
    Question: Who has the big tow mirrors? You ever take it through the auto car washes? I don't like folding them in because a) my mirrors don't auto fold and b) I don't like having half a mirror cleaned.
    Wand wash is typically a PITA but not looking to figure this one out the hard way.
  15. #2015
    Jan 2006
    Lately I've noticed a clunk from the rear when going up driveways or over speedbumps at an angle (not audible when going straight). Almost sounds like the suspension is binding. Any thoughts?
    2018 F150 non FX4.
  16. #2016
    Quote Originally Posted by 94boosted View Post
    2018 F150 non FX4.
    I have this intermittently on my 2018 Sport since new, it only happens when my wheels are turned though.
  17. #2017
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    2018 F150 non FX4.
    Put some EYE’s on the IWE’s.
  18. #2018
    Jan 2006
    Quote Originally Posted by SkiBum5.0 View Post
    EYE?
    I really don't think it's an issue with the IWE
  19. #2019
    Jul 2008
    Edmonton, Alberta
    Definitely won't be iwes. They make a grinding sound that is either that, or a blown diff. My truck used to clunk in the rear going over bumps. I figure it was just the awful stock rear shocks not doing their job. Went away with the bilsteins.
  20. #2020
    Dec 2008
    Unit 91 come in 91
    2018 F150 non FX4.
    My 18 Fx4 f150 did that. My Raptor does it intermittently as well. Rear spare clunking around. Plus it's a floating axel as well. Nothing to really worry about.
  1. Replies: 32
    Latest Threads: 08-01-2014, 05:24 AM
  2. Replies: 24
    Latest Threads: 01-10-2014, 07:08 PM
  3. 2013 Ford F150 /w Ecoboost
    By puya.ro in forum General Car/Bike Talk
    Latest Threads: 07-05-2012, 10:31 AM
  4. FS: 2010 Black Ford Flex LTD AWD Ecoboost
    By lint in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 05-22-2012, 10:14 AM
  5. The crazy Ford Ecoboost 3.5L V6 test
    By Cos in forum General Car/Bike Talk
    Latest Threads: 02-05-2011, 12:33 AM
