Ford Trucks Thread WAS:EcoBoost Thread - Page 77 - Beyond.ca - Car Forums
Page 77 of 259 FirstFirst ... 67 76 77 78 87 ... LastLast
Results 1,521 to 1,540 of 5178
Thread: Ford Trucks Thread WAS:EcoBoost Thread
  1. #1521
    1/32 is pretty reasonable amount of variation. Sounds like small town dealer that doesn’t want to work on a job that might tie them up.
  2. #1522
    thats what I feel as well... but I guess i'm SOL as it will be out of warranty shortly
  3. #1523
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    any chance you could put a vacuum pressure gauge on the IWE lines to rule a loss or vacuum pressure to them? or better yet pulling the tire and assembly to visually inspect the IWEs?
    I too would call BS on the tire variations unless you are always running the locker and on dry pavement. Each tire is able to rotate at different speeds (IE: turning), and a small amount of variance in tire circumference like that I would have to think is WAY within the tolerances for the entire driveline.
    Any chance you can take it to another dealer?
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
  4. #1524
    1/32 of an inch on a 32-33” diameter tire?
    Sounds like a rounding error to me... I bet most cars on the road are off by at least that much lol.
  5. #1525
    no outside of golden and I will be over the 100kkm by the time I get to calgary
  6. #1526
    Oct 2006
    '21 F150 PowerBoost
    well, is there a way you can try replacing the vacuum lines to the IWEs? They are pretty notorious for wearing at the clips and causing a leak which slows the 4x4 disengagement.
    Is towing back to calgary or having a second tech take a look at that dealer to specifically test the IWEs an option?
    Turbos cost money
  7. #1527
    Jun 2015
    LNF
    This definitely sounds like the IWE issue with vacuum. We had a 2013 F150 at work have the exact same issue while towing and it was the IWE and then they also had to change some lines like Spikers said.
    Your issue was reported at 99k.. So at least your issue was reported before the warranty expired, so it should still be covered once you get back to Calgary and your regular dealer.
  8. #1528
    Edmonton, Alberta
    Not an IWE issue. He stated the truck made grinding noises but did not move. If IWEs were at fault, the rear end would still be engaged.
  9. #1529
    Quote Originally Posted by ShermanEF9 View Post
    yeah not a IWE issue... drives just fine in 2HI and switches fine into 4HI, but I haven't tried low yet since I got it back...
    My neighbor says it happens once in a while if there was maybe too much pressure on the t-case, say using 4LO for towing (even on slippery surfaces)...
    I think as a precaution I should get the tcase flushed again
    I am now out of warranty :P
  10. #1530
    Dec 2008
    Quote Originally Posted by r3ccOs View Post
    One question, did you try to switch to 4lo while moving? I know technically you can under ideal conditions at very low speeds but you shouldn’t ever do this, would be extremely hard on the tcase if you attempted this while under load to boot
    Also wouldn’t be good trying to switch to low while on the ramp
    Switching to low while under load is never a good idea
  11. #1531
    Quote Originally Posted by J-hop View Post
    Transfer case is electronic and transmission needs to be in neutral before it will try.
  12. #1532
    Dec 2008
    Yea I’ve googled guys saying you can do it below 5 mph. I grew up driving a bronco with the very early auto locking hubs and you couldn’t do anything under load. The new electronic systems seem to allow people to do silly things.
  13. #1533
    Ford, Acura
    I need to get my speedo re-calibrated as I went with bigger tires and I am about 6% out now. I've noticed a HUGE difference in dealerships quotes to get this done and some who even said they won't do it. Does beyond have any recommendations on where to go, or what other options do I have to get it fixed? I Was thinking of maybe just grabbing a tuner like I ran on my 2004 Triton but with it still being in warranty I am iffy about that even though I have never had an issue with the truck. 2014 FX-4 Ecoboost.
    I'm generally cute.
  14. #1534
    Quote Originally Posted by schurchill39 View Post
    If it was ‘15+ I could do it using FORSCAN. I will read up on the 2014s and see what works on those.
  15. #1535
    A good buddy of mine who has always been a gmc truck man bought a 2018 F150 Supercrew 4x4 lariat sport with the 2.7 engine this week. He's been sending me pics and videos nonstop. I'm insanely jealous, while I drive my beater gmc.
  16. #1536
    Edmonton, Alberta
    i believe its a similar process. i actually think tire size is in the "quick changes" section in forscan.
  17. #1537
    This is for the 15+ https://docs.google.com/spreadsheets...#gid=110328400
    I can't find a 2011-2014 file, it must be out there somewhere.
    I have a module and a valid license right now.
  18. #1538
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    You should send a video of counting $750 each month when his payment would come out
  19. #1539
    Ford, Acura
    If one of you gentlemen could help me out I have a case of beer for you. Is Forscan the tool that everyone uses to do things like auto-fold mirrors, turn of the chimes etc?
    I'm generally cute.
  20. #1540
    Here is the 2011-2014 spreadsheet. Tire size shouldn’t be a problem.
    https://docs.google.com/spreadsheets...htmlview#gid=0
  1. Replies: 32
    Latest Threads: 08-01-2014, 05:24 AM
  2. Replies: 24
    Latest Threads: 01-10-2014, 07:08 PM
  3. 2013 Ford F150 /w Ecoboost
    By puya.ro in forum General Car/Bike Talk
    Latest Threads: 07-05-2012, 10:31 AM
  4. FS: 2010 Black Ford Flex LTD AWD Ecoboost
    By lint in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 05-22-2012, 10:14 AM
  5. The crazy Ford Ecoboost 3.5L V6 test
    By Cos in forum General Car/Bike Talk
    Latest Threads: 02-05-2011, 12:33 AM
