Fender rust repair? - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Fender rust repair?
    4cyl turbo diesel with a max speed of 10.9kmh
    Default Fender rust repair?
    Can i cut the rusted area out with a cut off wheel on a grinder? Second, what can i use to form/hold the fiberglass (without it sinking in) Thanks.
    335i
    Use some strong tin snips to cut it off. Much more precise.
    Don't use fiberglass. Try and shape a piece of sheet metal to it and weld it on.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Jul 2003
    Audi S3
    yeah weld in new metal, it'll be alot better in the long run.
    Jul 2003
    Screamin' Paintworks
    QX80, Viper ACR, RXT-X
    Just buy a new fender.
    Nov 2003
    for sum car u cant buy fender
    cuz its part of the frame
    Jul 2003
    Then it's not a fender.
    Perhaps you meant quarter panel?
    ya quarter panel sorry
    Nov 2003
    weld!! I have done it both ways and welding in a patch is far better unless you want to see the rust back in a few weeks, plus if you are using regular marine resin and hardener it doesn't adhere to metal all that great. Sure it will work for a year or two but no longevity out of it.
    If you can't use tinships try and get a thin cut off wheel andcut as much rust out as possible. Try to cut out the rusted area in a square shape, it makes it ways easier to place the new panel in.
    here are the steps i usually take. anyone feel free to correct me if you know I am wrong:
    1. try to determine how big rust patch is(usually pretty easy)
    2. with some sort of tin snips or sut off tool cut out the affected area.
    3. sand surrounding 2-3 inches of panel to metal for a good weld.
    4. if you can flange the area. The inset should be about 1-2mm so the metal can sit flush, elimating the use of a lot of bondo.
    5. clap the new patch in place or just hold it really firmly so it doesn't jump when you weld.
    6.tack weld the panel in place and spread all your wled out so you get less heat warpage.
    7. grind metal down and fill any ramaining pits or pund any high spots out.
    8. prime
    10. paint
    Iguess it's kinda off topic because you said you were using fibre glass but I hope this might help and you could always get some metal and cover it with some wax to prevent the glass from sinking in.
  1. extreme rust repair
    By Lo)2enz0 in forum General Car/Bike Talk
    Latest Threads: 03-19-2003, 09:12 PM
  2. rust??
    By JohnnyBlaze in forum Mechanical
    Latest Threads: 03-19-2003, 02:48 PM
  3. rust!
    By HK2NR in forum Mechanical
    Latest Threads: 02-06-2003, 09:50 PM
  4. Rust Check; any place in Calgary?
    By Horatio in forum General Car/Bike Talk
    Latest Threads: 01-20-2003, 12:42 AM
  5. Rust on a new car ???
    By Steel Angel in forum General Car/Bike Talk
    Latest Threads: 06-17-2002, 02:49 PM
