Rotary engines are always a nightmare, and I am trapped in it right now.
Wednesday night my rx8 crapped out on me. Was driving the car all day with no signs of issues. After an hour or 2 of driving my throttle lost all power and was virtually unresponsive. Pull aside on the road and it stalled at low rpm and very heavy idle.
Car starts (most of the time now) but has heavy idling and stalls if I do not manually keep the rpm over 1k.
The car is barely drive-able. Drove it home from where it stalled initially but had to keep the RPM over 4500 in order for it to keep remain at constant speed. Very rough idle throughout.
Now my car is towed to the dealership and I am told that I need to get full maintenance to see if that helps first. HOWEVER this costs 1200 bucks with no guarantee that this is the root of the issue. Even after getting this done if the problem still remains, I may need to still replace the engine (another 5-6k on top of the 1.2k).
This maintenance includes : spark plugs, coils, and wires, with labor.
If anyone here can give me suggestions, or knows someone who can fix rotary engines well PLEASE let me know! My car is not worth a fix of over 2500.
I am right now contemplating on only replacing spark plugs costing around 360 at the dealer.
***UPDATE*** July 7
Changed all spark plugs and coils (used coils that are in good condition from 5g_celica, thanks again).
unfortunately the car had zero changes or affects. the engine is toast or virtually dead. I will have to figure a way to get warranty since I am technically still covered by warranty however the dealership I am at right now is saying I dont have a solid oil change record and is voiding my warranty (receipts to prove I have maintained the car).
I will be trying a different dealership tomorrow.
